dc wiring harness in crx?
Old Jun 1, 2010 | 06:17 AM
bradennicely's Avatar
Icon2 dc wiring harness in crx?
anyone every done this?
i have to buy an entire harness cabin and motor.. cant seem to find a rex one but i found a 95 teg complete harness for 100..
i dont plan on running heat im just leaving the bare minimum in hte car
Old Jun 1, 2010 | 06:20 AM
-NA-aLL-thE-wAy-'s Avatar
EFSS153
Default Re: dc wiring harness in crx?
That sounds like a ton of work for no real benefit. I actually have an entire cabin harness from an '89 hatch if you want it. $60 shipped. Check out the part out thread in my signature for details.
Old Jun 1, 2010 | 06:26 AM
crx_si-r's Avatar
i have a full cabin harness from a 89 crx, ill have to check tho. and there is a complete dx crx at the local yard. just wait and get the one that is meant for your car. it will require too much work to get the DC harness plugged n working right. plus there are a crap load of them on ebay as well.
Old Jun 1, 2010 | 07:54 AM
how hard could it be? im not using heat/ac so the only things that would be hoked up was tailights headlights radio cluster everything for the engine
Old Jun 1, 2010 | 08:05 AM
crx_si-r's Avatar
your dashboard harness is NOT the same, and will need to be modified (or custom made) to work with the DC harness. not to mention the under dash fuse box will have to be re-located because they have a smaller one that bolts to the side kick panel (unless your gonna leave it hanging there). if you decide to use a stock fuse box, then you will need more custom work. as well as the actual dashboard harness. this will also need to be modified to work with the DC harness. and im not talking about the heate/ac controls. the cluster is different.
Old Jun 1, 2010 | 08:06 AM
crx_si-r's Avatar
also the engine bay fuse box will need to have some work done to it as well.
Old Jun 1, 2010 | 08:30 AM
lunalink's Avatar
Just wait and find yourself a harness meant for your car.
* trust us making harnesses takes some time and aint easy
Old Jun 1, 2010 | 11:42 AM
well.. i think u guys have talked me out of it..
next ? anyone one selling one? entire crx harness? si or not
bodiez
Apr 3, 2011 07:36 PM
ikaika3269
10
Feb 26, 2008 06:25 PM
90b20b4
Nov 2, 2006 08:11 AM
h22delsol
Oct 18, 2006 12:19 PM
oneslodx
Feb 19, 2004 02:25 PM
