type r wont start please help
alright so now the car wont start. i have fuel.......i have spark.......i checked all fuses......even swapped out the ecu and dizzy and still nothing it just cranks. plugs are good.
anyone have any ideas?
wires are good. order is 1-3-4-2 starting from bottom left and going clockwise.
guess ill have to check the timing in the morning.
is thier anything else it could be?
ive never seen this problem and ive been messing with hondas for over 10yrs
I'd also check fuel pressure and the actual gas. I've had a Chevron station pump 1/8 tank of water in my civic recently. I just cranked all the water out and she ran fine afterwards. So it just cranks, and doesn't attempt to fire?
Not sure if its possible but could you have maybe put the distributor 180 off in the cam slot? I know one side is slightly larger but ive heard of it happening (never seen it though), just weird that it started after you swapped distributors.
but its weird how these spark and fuel and it wont even burp
