Oversized Pistons????
Old Sep 12, 2002 | 09:22 PM
Fly1865's Avatar
Default Oversized Pistons????
OK i have a H22A4 it has only 8k on it. I want to change the piston out to the Type-S pistons. About the oversized, is there anything that can be gained from oversized pistons or do they make those just cause of the wearing of the block after time. Which should i get? I'm at a loss and i don't know which to choose.
Old Sep 13, 2002 | 01:06 AM
HondaTypeS's Avatar
Default Re: Oversized Pistons???? (Fly1865)
I'm getting the oversize Type S piston myself. Honda made the 0.25 oversize OEM Type S piston. My car have 113,000 miles, with 8000 miles that you have, I wouldn't do anything internal if I were you. Putting an oversize piston will gain more torque and power but nothing crazy though. Don't expect much from it.
Old Sep 13, 2002 | 05:16 AM
aklucsarits's Avatar
New User
There is no real performance advantage to Honda's oversize H22A pistons. They are just intended to be used when rebuilding a block that has had the FRM liners honed.
Andrew
Old Sep 13, 2002 | 05:53 AM
Fly1865's Avatar
Default Re: Oversized Pistons???? (aklucsarits)
Well i have to get my crank, rods and pistons balanced. So i have to take the motor apart to do so, cause i had a problem with the oil pump and ran the motor about 9 miles without oil pressure. SO i'm getting mew main and rod bearings and i was thinking while it was out to go ahead and balance it since it was out so i don';t have any future problems. And since i have to do that why not replace the pistons with a little bit higher compression, without having to get the block resleeved and that the Type-S pistons were the way to go. I was just unsure on if i should buy standard or oversized pistons to go in the motor.
Old Sep 13, 2002 | 06:36 AM
New User
If you have the cylinders honed to the overbore spec while the engine is apart, you use the overbore size. If not, you use the regular size. The honing specs and procedure are in the Helm manual. Most people recommend honing before replacing the pistons with new ones, even if there is no visable cylinder wall damage.
Andrew
Old Sep 13, 2002 | 08:08 AM
Fly1865's Avatar
So then i should go ahead and get the oversized pistons then.
mikeaitken
Apr 23, 2007 03:16 PM
b18sihatch
Jul 10, 2006 08:35 AM
hookups214
Jan 27, 2006 09:07 AM
99blackvti
Sep 7, 2005 01:46 PM
