D15b2?
you're better off finding a D16A6 to build for turbo then swap in. you will, at a minimum need several parts from the A6 anyway to do a DPFI>MPFI swap so you can get enough fuel into the motor to run a turbo.
may as well spend the extra $150-200 for the whole A6 so you have the option of running off the shelf internals.
well sleevling the block is big so i dont wanna go that far.just something more then it has but hah i mean the motor stock has hole 92hp.maybe in the long run it would be better to go with a JDM b16 swap
