temperature needle rises when fan turns on
Old May 31, 2010 | 02:49 AM
aasaa666's Avatar
Default temperature needle rises when fan turns on
I have a situation with the needle rising when suddlely rise up just a little over the half mark when the fan turns on, and when the fan turns off it goes back down to normal temp reading on the temp gauge. Has anyone ever encounter that problem? its a little weird to me since this is the first time I've encounter this situation. Any idea what that could be?
Old May 31, 2010 | 06:12 AM
HondaPartsHero's Avatar
Technical Hero
Default Re: temperature needle rises when fan turns on
have you checked your coolant level?
Old May 31, 2010 | 07:15 AM
phootbag's Avatar
Make sure your fans are spinning the correct direction. If they blow forward this can happen.
la_teta
Oct 5, 2010 02:49 PM
walrus_07
Feb 21, 2009 10:16 PM
93LS
Jan 29, 2008 03:39 PM
macrob68
Jun 15, 2006 04:16 AM
rextec
21
May 17, 2006 05:43 PM
