b18 main relay clicking like crazy
Old May 30, 2010 | 08:00 PM
EF9_RIDER37's Avatar
Default b18 main relay clicking like crazy
what up peoples aite this is whats up i have my ef and i swaped in an ls but it worked fine and all of a sudden it would die on me i though it was a fuel problem but i had everything from spark to fuel it was cool. i searched and some said to replace the main relay i did and now it still does that dumb crazy clicking and wont let me start my car others told me to check all my grounds and make sure everything is running cool i need help guys any help would be greatly appreciate it thanks guys.
Old May 30, 2010 | 09:40 PM
gera_em1's Avatar
Default Re: b18 main relay clicking like crazy
i got a 00 si & i just dropped in a poor mans type R in & it does the same thing!!! i just changed the rotor & cap on the distributor. it starts in the morning when it's cold but when i drive it, it dies & wont wanna start? im really confused & dont know where to start
Old May 30, 2010 | 10:31 PM
BadassEFdriver's Avatar
yup could be the main relay, mine did the clicking and even died on me once while driving too. Got a relay from advance for $40 bucks, changed it, It was all good, didnt have that problem again...and make sure you have good ground from the engine to the chassis too
Old May 30, 2010 | 11:16 PM
ef yu's Avatar
My friend had the same problem. turned out to be a grounding issue with the Ground Terminal on the battery. check that and all other grounds. good luck!
Old May 31, 2010 | 03:14 AM
Jenkinsal2's Avatar
BINGO! Check your thermostat grounds, engine/batt ground wires, and if all else fails splice a new ground in for the main relay.
Old May 31, 2010 | 05:47 AM
blasterman87's Avatar
check grounds. take the relay apart and look for cracks in the solder joints. if cracked solder them back together.
Old Jun 1, 2010 | 10:26 AM
aite this is whats up i just checked all my grounds and powers and i seemed to be good i took like 5 main relays and some off DAs and i tryed them out one got it to start but then it would die right away the others would not let the car crank over and they started to click like crazy so my question is since my car was a std model dx wich came dpfi do i have to have a main relay maybe off an si to run the ls i have in the car cus all the main relays that i took were from other dpfi
Old Jun 2, 2010 | 02:06 PM
bump
Old Jun 2, 2010 | 03:20 PM
Jenkinsal2's Avatar
Your problem is, As stated above...a bad ground. You say you "checked" this. How? Wiggle some wires...? get a multimeter and fix the ground.
Old Jun 2, 2010 | 04:31 PM
crxdrosky's Avatar
check the ground with a multimeter from the the relay to the negative battery post (u might need a long lead) and it should not have more than .03 v of resistance.... if u think its a ground problem... when a relay click it is being energized so thats what the clicking is... u can also use a jumper to check if its the relay
Old Jun 2, 2010 | 07:53 PM
just replace the grounds. costs like 20 bucks and will save you problems in the future. there 20 yrs old, there bound to be corroded
Old Jun 3, 2010 | 06:26 PM
aite ill check them out but does it matter since i had the main relay of a dpfi on a std model do i need one of an si
Old Jun 4, 2010 | 06:00 AM
JDMkid413's Avatar
no if it fits it fits.. and instead of getting a shitty used one go get a new one from ur local auto parts store they are about $50...
Old Jun 6, 2010 | 08:00 PM
aite guys i checked my grounds and i got a good relay and i put it on and it started up but after like 6 sec. it died out and did the same thing and started clicking like crazy
what else can be the problem
Old Jun 6, 2010 | 09:24 PM
Dumped Ek's Avatar
just screwred around with that today on my friends ef9 rhd...the main relay would tick..then tried starting it ...then the relay would buzzz...cleaned some of the ground replaced a few..(got em from honda bout 30$) worth every penny im all worried. the battery was weak as well so changed that to...everything runs perfect now..like new!
Old Jun 7, 2010 | 09:18 AM
woooooooohooooooooooo peeps i did what dumped ek said and i cleaned all my grounds and relaplaced grounds and the car started right up im going to test drive it in a bit to check if everything is okay thanks for the help guys
Old Jun 7, 2010 | 05:32 PM
crxdrosky's Avatar
all u had to do is check for resistance like i told you and u would have figuered it out to begin with
Old Jun 8, 2010 | 08:24 AM
i know my dumbass was going crazy but thanks for the help bro im about to test drive the RANFLA lol
Old Jun 8, 2010 | 08:28 AM
crxdrosky's Avatar
hahaha
Old Jun 8, 2010 | 11:29 AM
ED94LIFE's Avatar
glad you got everything figured out
collkid
13
Sep 16, 2015 09:10 PM
boostmyda
Jun 2, 2010 07:08 PM
redcivic13
Sep 29, 2008 08:50 PM
silentblackhat
Jun 10, 2005 07:55 PM
JQE80
Sep 3, 2002 07:19 PM
