b18a1 in my crx. pleaseee helppp with fuel problem
Old May 30, 2010 | 06:06 PM
ehansford22's Avatar
Default b18a1 in my crx. pleaseee helppp with fuel problem
ok so i just swapped my crx, dual point to full fuel, i did all the wiring right for sure! its a b18a1 with a b16 tranny, my fuel rail is getting gas to it so the fuel pump works but the injectors arent get gas and shooting into the motor??? what could it be, i have a hf single cam crx ecu and a 89 prelude b20 ecu? could it be those or could it be the resistor box or maybe bad injectorssss, can anyoneee HELPPPPPPP MEEEEEE PLZZZZZZ
Old May 30, 2010 | 10:35 PM
BadassEFdriver's Avatar
Default Re: b18a1 in my crx. pleaseee helppp with fuel problem
..or I would check the resistor box too
Old May 31, 2010 | 05:58 AM
blasterman87's Avatar
first off get the right ecu, and is there power to the injectors? like are they pulsing or no? if not it could be alot of things...
Old May 31, 2010 | 07:59 AM
how do you check if there pulsing??? and im working on gettin the right ecu lol but yeaaa alot things suck haha im gettin another resistor box today and a set of injectors. we'll see what happenssss thank you for the help also
Old May 31, 2010 | 08:01 AM
Originally Posted by BadassEFdriver
Attachment 133722
lmaooo good one. haha ill put some seafoam in there. should work better but yea like i said to the other reply, im gettin a diff resistor box and injectorsss todayyy hopefully so we'll see how it goessss. thanks for the help too
Old Jun 2, 2010 | 07:43 PM
ok so i got the ls ecu. i was reading the blinking codes off it i got a code 8 and 10. one was top dead center position (tdc sensor) and the other is intake air temp (iat sensor) what do you guys think. help a EF-er outtttt!!!
Old Jun 3, 2010 | 07:30 PM
i have no spark nowww so it must be the dizzy right???
Old Jun 3, 2010 | 08:18 PM
BrandonR's Avatar
Could be. Check your wiring.
Again.
Later, BR
Old Jun 3, 2010 | 11:41 PM
Prodigy [EM2]'s Avatar
Try using a fuel pressure regulator. My injectors weren't getting fuel either and the fuel was returning and not creating pressure, put a new FPR and it worked
Old Jun 4, 2010 | 01:52 PM
ok so changed my dizzy. now i got a code 4. crankshaft position (ckp sensor) im gonna redo my timing, what do u guys think?? will it start if i have that code tho?
ef9smashing
Aug 4, 2010 08:58 PM
90dxb20
20
Apr 1, 2009 08:33 PM
scott_kusch
Mar 27, 2008 07:07 PM
646EG
Jan 22, 2008 05:12 PM
