98 Coupe door locked!!
Old May 30, 2010 | 12:41 AM
tonyasleep's Avatar
Post 98 Coupe door locked!!
Hi there,
I have a 98 2L Coupe. Last week the door locked and will not unlock.
when I press the remote key fob I can hear the two clicks, same when I pull the pin up from inside, and no luck when pulling the innner door handle, the door refuses to open!
1. Any ideas on how to get the door open so I can remove the inner panel to effect repairs?
2. Any thoughts on what the cause of the actual fault with the door locking mechanism could be?
many thanks in advance...
Tony
Old May 30, 2010 | 12:41 PM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: 98 Coupe door locked!!
So its automatically relocking the door after you unlock? How about pulling the negative on the battery to kill the power. Should be able to unlock the door without it relocking.
I thought there was a sticky on this in the FAQ... nope don't see it. IIRC its a limit switch that is inside the actuator that becomes stuck in the lock position.
Old Jun 4, 2010 | 06:37 AM
tonyasleep's Avatar
Originally Posted by MAD_MIKE
So its automatically relocking the door after you unlock? How about pulling the negative on the battery to kill the power. Should be able to unlock the door without it relocking..
I hear two clicks which ever way I attempt to open the door, sorry not technical enough to know if it is relocking the door.
I have tried disconnecting battery to no avail......still refusing to open!
Old Jun 4, 2010 | 06:48 AM
Senior Taco's Avatar
How did you ever manage to get out of car!?!?.. jk
Is the pin going back in when u pull it up?
Do you have a slimjim? (some cops have it to if you know one that can help u ex. neighbor) maybe a Pop a Lock near by?.
Maybe if you can find a way to manually pull that lock up, it should hopefully let you back inside.
From there id pull the panel off like you said and start checking everything out.
Old Jun 4, 2010 | 07:58 AM
sgraham01's Avatar
have you tried holding the key in the door in the unlock position while trying to open it?
Old Jun 13, 2010 | 04:09 AM
tonyasleep's Avatar
Thanks to all of the above but to no avail.....
I have managed to get the top part of the inner door trim off and taken the passenger side door trim off for comparison.....
All of the internal workings of the lock/handles appear to be working correctly as compared to the passenger door
Any suggestions are GREATLY APPRECIATED!! I'm getting too old to keep climbing in through the passenger side!!
Scott Younker
May 28, 2019 07:33 PM
JTyson86
Jan 9, 2012 02:11 PM
micks civic
May 6, 2008 10:08 AM
Ep1dem1c
May 7, 2007 10:14 AM
camera obscura
Feb 10, 2003 07:50 AM
