xenocron ecu management
hi from germany.
i will tuned programming myself ecu.
http://www.xenocron.com/diyer-intro-...age-p-238.html
http://www.xenocron.com/te.php?page=te_cover
http://forum.pgmfi.org/viewforum.php?f=56
it is difficult and any positive experience
aem ore hondata is to expensive for me.
infos please.
thanks.
infos please.
thanks.
Add up the cost of the hardware plus the software, then compare it to Neptune, Hondata & eCtune.
The price difference is minimal & you are going to end up with a much better tuning experience on an alternate system.
i will tuned obdo ef9 turbo gt30 550 injectors
there is only a small number of car tuner in germany maybe 5 people how cant programming honda ecu for turbo upgrade.
price is 300-400 euro (witout warranty)
the ignition and the wideband sensor must control correctly at the programming?
not to slim and not to fat adjust.
what the alternate system?
my English is a bit rusty (not well). else i will immediately to do this **** oneself.
300-400 Euros ($375-500) is a bit tight of a budget for Neptune, Hondata, or Ectune. You're going to be stuck working with Freeware software. Now theoretically you may be able to get away from not buying a wideband due to the fact you can use the dyno shops or maybe another local's wideband.
OBD1:
--Chipped P28 ECU - $150
--Harness - $90
--Ostrich - $175
--Datalogging - $35
--Crome Pro - $150
--LC1 w/ Gauge - $180
Total: $780
Comments: You can run Crome free and datalog via something else like Innovative's software. That will save $185. OBD1 tuning solutions are simply better than OBD0 at this point.
OBD0:
--Chipping Kit - $30
--Ostrich - $175
--Datalogging - $35
Total: $420. Remember OBD0 software is less refined than even Crome. It works, but most people want you to convert to OBD1.
OBD1:
--Harness - $90
--Ostrich - $175
--Datalogging - $35
--Crome Pro - $150
Total: $780
OBD0:
--Ostrich - $175
--Datalogging - $35
But in Germany are two guys (MKR) with an own develpopment in awsome OBD0 software and experience. So there is no real need for converting to OBD1.
But they can also help you out and tune your car for a good price.
I can imagine you know the site www.mkr-turbo.de
There is STILL development going on with TurboEdit software and they have found more tables to play with...you need to hop over to PGMFI and join up:
HAMOTORSPORTS
Performance
783
Jan 19, 2013 12:45 PM
ecu, experience, honda, hondatech, management, managemnet, obd, phearable, review, reviews, solutions, tech, tuned, tuning, xenocron
