QUALITY 1st Generation B16A swap COMPLETE
Located in Pittsburgh PA.
Ok Boys and Girls, If you're looking to go b-series in any 88-91 civic, look no further. It's your lucky day. Over the past few years, I've been collecting every single part, nut, and bolt, to swap a b16 into any ef chassis. A few months ago, I ran into some money troubles and needed to sell my CRX, the car I had patiently waited to swap. Now I'm left with nothing but the swap sitting in my garage, and since I'm so picky on what EF I will buy, I have decided to sell all my parts and wrap this chapter up. So here's whats for riddance.
-1st generation B16A swap, originally purchased from hmotorsonline.com, the engine was then dissassembled and wiseco low compression pistons were installed along with new, timing belt, water pump, head gasket, valve seals. Approximately < 400 mi ago. Block is tapped for turbo oil line.
-Comes with-
*Blox ITR replica intake manifold
*DSM bluetop injectors
*New Remanufactured Axles
*92-95 Civic Radiator
*Avid Motor Mounts
*Shift Linkage and Shifter
*Alternator, belts
*Distributor
*Clutchmasters Stage 3 Sprung Clutch.
*Starter, PW0 Ecu, all hoses, bracketry, and hardware to drop in.
*YS1 cable Transmission, no grinds.
*Brand New ETD Traction bar.
I would like to sell all of this as a package, it will make someone swap experience painless, as all you would need is a wiring harness to have a running car. No reasonable offer will be refused!
-B18a1 Long block. Donor was and automatic integra. $250
This was my swap candidate.
Please PM me if you have any questions whatsoever. I may have left some things out so I will be revising day to day. Thanks for looking!
-Comes with-
*Avid Motor Mounts
*Alternator, belts
*Distributor
HogHead
Southeast (Sales)
16
Feb 14, 2010 05:25 PM
