92 prelude S
Old May 29, 2010 | 06:54 PM
civicorprelude6's Avatar
Default 92 prelude S
does anyone have a detailed write up with pictures on how to change the front and rear brakes? im changing the rotors, calipers, pads and wheel beerings. I've heard its not very easy...
Thanks for the help
Old May 29, 2010 | 08:22 PM
Kronn 98SH's Avatar
Default Re: 92 prelude S
You heard wrong. It's quite simple.
Remove the wheel.
Unbolt the caliper.
Unscrew rotor.
Replace in reverse order.
If you REALLY need something more detailed, get the service manual.
Old May 29, 2010 | 09:06 PM
well you have to take the rotor it off the hub and you end up ruining the wheel bering doing that. dont you?
Old May 29, 2010 | 10:11 PM
Kronn 98SH's Avatar
I didn't say anything about a wheel bearing.
Old May 29, 2010 | 10:21 PM
2ksh's Avatar
you only replace the wheel bearing if its bad, not during brake jobs. just like kronn said, remove the wheel, caliper, caliper bracket, tap rotor with hammer to break rust free and remove.. then just reverse the order, after compressing caliper piston back and apply your grease.. good luck.
Old May 30, 2010 | 09:56 AM
oh alright, well see what happens. Thanks for the help
Old May 30, 2010 | 06:12 PM
Kronn 98SH's Avatar
yw
greenthumber
Jan 28, 2012 01:39 PM
DOHCRAZY
May 26, 2006 06:13 AM
turbob16ef
Suspension & Brakes
Sep 3, 2005 12:16 PM
SunkistRex
Mar 21, 2004 08:06 PM
DEVIN22CBR
Jun 6, 2003 08:07 PM
