1991 Honda CRX
Old May 29, 2010 | 04:54 PM
joann1874's Avatar
Default 1991 Honda CRX
Will not start. I have tried to check to ECU codes but the light is not burning. Does the mean the computer is bad or could the problem be elsewhere?
Old May 29, 2010 | 08:59 PM
4crx4me's Avatar
Default Re: 1991 Honda CRX
Have you checked the main fuel relay?
Old May 29, 2010 | 11:12 PM
shift_wagovan's Avatar
I has a similar problem in my sedan. I wasn't getting power to the ecu or fuel pump. Main relay checked out good tho. Ran a jumper wire from + battery to #5 connection on the main relay and it worked like normal. Therefore I now have to trace wires from the main relay back to figure out my problem. Might be yours too idk tho.
Old May 30, 2010 | 06:01 AM
jlicrx's Avatar
no power to ECU and Main Relay usually means that you don't have the ground wires connected at the thermostat housing - ground wires come out of the engine harness next to the thermostat housing - has a small ring connector on the end that bolts to the thermostat housing - it is the ground for the ECU and Main Relay as well as for the shielding and most of the sensors
Old May 30, 2010 | 01:51 PM
sagebrush07's Avatar
X2
91_Project
May 22, 2014 07:42 PM
WideBodyTypeR
May 29, 2012 04:36 PM
DDTECH
May 11, 2012 08:42 PM
JAlvarez
23
Feb 9, 2011 10:18 AM
DualCamEK
Nov 21, 2004 07:01 PM
