b16a2 build ?
im planning on building a motor soon...heres what i plan on building
b16a2 out of a 99 si
eagle rods with j.e 11:1 or 12:1 pistons ( whats your opinion)
bored .20 over
supertech valve train and skunk 2 cams
ported head
skunk 2 intake manni.
act clutch
hondata s300 (not 100% on it yet though)
hasport mounts
70mm tb
rc injectors
hytech header
my goal is to reach close to 200hp then put a 100 shot on it...how does this build sound? anything else i should get ?
bored .20 over
ported head
act clutch
hasport mounts
70mm tb
rc injectors
hytech header
Sounds like a pretty standard money bleeding A/M build to me.
But you won't get close to 200whp with 11.1 OS pistons in a B16. If you're scared of the c/r you should consider a blockguard, assuming you can, when you're honing at the machine shop while going for the 12.1's. Consider your headgasket options too. In fact, just buy a standard 3-layer OEM HG and remove the middle layer, it's basically the same specs as Spoon/Mugen without spending the money.
which skunk2 cams? those will make a big difference on what power out put will be. also Iv seen a few people say that the hy tech rep isn't very good for a b16, look into a s.p. toda replica header, thats gonna be your best bet for making power.
hyperblu
Mar 29, 2011 08:39 AM
Irishweird00
40
Oct 18, 2004 08:50 AM
