Building 200 WHP
Old Sep 12, 2002 | 07:27 PM
Stryker908's Avatar
Default Building 200 WHP
With a b16a Hydro ..... thoughts on what I will need to do right now im looking at an intake manifold, throttle body, double springs, titanium retainers and , skunk2 spec 2 cams,... along with my dac intake, dc 4-1 headers test pipe and tanabe exhaust ..... Think that will put me close ? what else you think i should be concidering ?
Old Sep 12, 2002 | 07:30 PM
Stryker908's Avatar
Default Re: Building 200 WHP (clean_dc2)
Rather build my engine then boost it just the way I do my thing
Old Sep 12, 2002 | 07:39 PM
TwystedSpeed04's Avatar
Default Re: Building 200 WHP (JDM_SIR_II)
Im sporting you all the way on that, whats the point of adding instant power to your engine and making a hassle to work on it. Id much rather get all the power i can, then strap on a drag 3 and smoke the locals. 200whp? Why would you want to build your engine to only 200? My little cx is already pushing 300whp <U> </U>
Old Sep 12, 2002 | 07:42 PM
Stryker908's Avatar
Default Re: Building 200 WHP (TwystedSpeed04)
I was trying to be realistic ......... on my budget ... Its just the number I picked to shoot for ..... Trust me I know when I get there .. I will want more ... what have you done to build 300 hp N/A ?
Old Sep 12, 2002 | 10:01 PM
mannyman's Avatar
El Veterano de Sur Califas
hahahaha....300 hp N/A???? now that was funny
Old Sep 12, 2002 | 11:15 PM
Westrock2000's Avatar
Default Re: Building 200 WHP (mannyman)
it's gonna take some RPM to get there. Since the B16A is a little anemic on torque, your gonna have to get the horsepower by way of rpm's. If you can maintain 125 ft-lbs at 8500 rpm's you'll be making 205 HP. I would recomend high comp pistons in order to keep the power from dying off up top. Also a short runner intake manifold, like say the JG Eddelbrock Victor X, and definently an upgraded valve train; nicer valve springs, titanium retainers, stainless valves (less weight), and some bigger cams (check out crowers). Maybe even an electric water pump, as not to have the parasitic drag at high rpm's.
Old Sep 13, 2002 | 07:48 PM
advanracing62's Avatar
Default Re: Building 200 WHP (Westrock2000)
I'm also trying to hit 200+ NA... seems like the best way to do it is either compression or go to 1.8 by means of a stroker or a B18C block. I'm sitting just under 190 with JUN III head and some other things. Compression is about 11:1 roughly.
Old Sep 13, 2002 | 08:40 PM
Stryker908's Avatar
Default Re: Building 200 WHP (advanracing62)
what engine you using ? mods list ? exact hp from them ? what RPM do you get those numbers from ? ... For my daily driver hitting 200 hp at 13,000 RPM .. Dosent do me much good ... Thanks for all the good advice so far guys ! Ill let you know it goes !
Old Sep 13, 2002 | 08:51 PM
EKhatch's Avatar
If you want 13,000 rpm's you can buy my CBR! Otherwise good luck on any kind of budget. 200hp N/A isn' t as easy, AKA, cheap as you may think even when measured at the flywheel. Good luck, let us know what you come up with.
Old Sep 14, 2002 | 12:00 AM
Stryker908's Avatar
Default Re: Building 200 WHP (EKhatch)
200 is a goal ... Its something to work to .... So I can say 50 more hp .. and those cams gave me 15....... Otherwise I dont have any way to "keep score" If you know what I mean ... and I said I dont want to rev to 13,000 I want to make usable power
[Modified by JDM_SIR_II, 9:01 AM 9/14/2002]
Old Sep 14, 2002 | 08:02 AM
nto revving to 13k... just 9,5k. I'm doing this with a B16 so far. Like I mentioned I still want to trade up to a B18C bottom for more torque and displacement. I think overall the cams with the compression was the biggest stepping stone to get to close to the 200 whp mark. Mainly I'm using all JUN except for the stroker kit, cams, gears, valve springs, retainers, header, flywheel, clutch. And then I'm tuning it with Hondata III. There is no AC or PS attached to the motor. I'm using a special blend of oils for the motor and regular 92 oct. fuel. I won't bump up the oct. until I go to 12.5:1+ compression. I know that if I were to change compression 200 whp should be VERY attainable. If you want a complete list of mods pm me.
Old Sep 14, 2002 | 10:40 AM
dohcsideSi's Avatar
1.8 or 2.0 block 11.5-12.5 compression and skunk stage 2's. and a hondata ecu should bring you to 190-195 w/ the 1.8 and closer to 210 w/ the 2.0
Old Sep 14, 2002 | 04:11 PM
Quick 200k Mile Motor's Avatar
Default Re: Building 200 WHP (hndarcr)
looky here..
https://honda-tech.com/zerothread?id=274139
not there yet but that is amazingly close.
Old Sep 14, 2002 | 04:12 PM
FrostyDC4's Avatar
"Haters Gonna Hate"
25 Year Member
200whp is possible from a B16. It just takes money . Just curious what is your set up b/c I am at 200.3whp with a JUN III head but I have a crazy 12.5:1 (at least) cr?
Old Sep 14, 2002 | 04:36 PM
Choppa's Avatar
Default Re: Building 200 WHP (FrostyDC4)
FrostyDC4
can you elaborate on your setup please? go into specifics.!
It sounds like my setup (currently being built) is going to be similar to yours, and i was curious as to how much power i could expect
Thanks
Old Sep 14, 2002 | 05:36 PM
FrostyDC4's Avatar
"Haters Gonna Hate"
25 Year Member
Default Re: Building 200 WHP (Choppa)
FrostyDC4
Thanks
93 GSR
B16a
Ported and polished head
Head milled .02"
extrude honed type-r mani
Jun Valvetrain
Jun cam gears
Jun III cams
At the time I was using the JUN ecu but I have hondata stage2
Aem Intake and fpr
JDM 4-1
2.5in exhaust w/ N1 muffler
Fully balanced counterweighted and knifeedged crank
JE 12.5:1 cr pistons (81mm bore)
ACT clutch w/ 10lb flywheel
VAFC
Eagle rods
ARP head studs
RC 65mm tb and 310cc injectors
I think thats it.
[Modified by FrostyDC4, 6:37 PM 9/14/2002]
Old Sep 14, 2002 | 06:33 PM
rOby's Avatar
sleeve and bore to 2.0, b16 or type R head fully ported and polished, full valvetrain and skunk2 stage2 or jun 3's. 12:1 comp ...ull be there at 200.
hondata 2
Old Sep 14, 2002 | 06:57 PM
shermanyang's Avatar
Default Re: Building 200 WHP (roby)
going n/a is way too expensive for me. but good luck, i know i'd rather have a 300+whp n/a car. but i don't think i could afford the build up. tell us how it goes when you're done.
jdmgeezer
Oct 3, 2007 09:50 PM
ftwlucky13
22
Mar 20, 2006 12:53 PM
msinsky14
Nov 8, 2005 07:27 PM
MansuDC2
Aug 2, 2005 05:20 PM
Mikes01GSR
Apr 22, 2002 05:12 PM
