96 ex accord tranny issue?
ive had my accord since 70,000 miles now its 170,000 its always slipped. or the rpms rev up and wont shift unless l let off the gas. im thinking it has to be the torque converter what do u think? also drives great in d3 only does this in d4
Have you ever changed the transmission fluid? Have you looked at the FAQ section and checked the shift solenoids?
yup l have changed the fluid a while back and no l havent checked shift solenoids. l know they are the two round cylinders on top of tranny but not exactly sure how to test them out.
There is an illustrated link with how to check them but for the life of me I cannot find the link.
well thank you very helpful info. l like to do all my work myself, honda is way to expensive and dont trust others. since l have so many miles l was thinking of just replacing it. but ive heard those jdm trannys dont always work. l dont wanna run into that prob. you know where l could get a new or good rebuilt one for good price? with warranty thanks mike
lm thinking a f20b swap will be cheaper and more power then trying to build my f22b there like 1500 for motor,trans,ecu,wiring harness. tranny from jdm is gonna be 400 and a new head which l need is like 370
yea but having 170,000 miles plus when l went to change my head gasket before cuz l dont think it was ever done from the person l got it from, the valve cover bolts well 2 of them broke off the threads were heated in they broke off in the head. big prob l had to try to drill and tap them out didnt work. so l ended up have to put heil a coil in the 2 spots and put a all thread bolt with a wing nut so.... lm kinda ready to do a swap if not a complete overhaul
@madmike, is the connector for the transmission in the same location on the 96 ex 4 cylinder? I had me rear main seal replaced a few months ago anf am noticing the tranny slipping when warm. Also had the tranny oil replaced. Maybe need tranny flush?
micahd02
Aug 3, 2018 12:44 PM
