cars running too hot????????????
Old May 29, 2010 | 04:37 AM
thegatekeeper14's Avatar
Default cars running too hot????????????
ok so i have a ls/vtec and while driving with the heat off even normal 5h gear (which is running rich BTW) the car over heats. but if i turn the heat on it very slowly begins to reduce in temps. the cooling issue was much worst, today i fixed it cuz b4 i had the 2 larger hoeses on the thermostat housing swapped the one gooing to the head and the other for the heater were backwards but seems better now. the little hoes off the intake is plugged. and i have the TB and IaCV lines coolant lines disconnected as well.
Old May 30, 2010 | 12:29 AM
95DC2GS-R's Avatar
Default Re: cars running too hot????????????
What kind of water pump do you have?
Old May 30, 2010 | 12:23 PM
Stock. If it was bad the heat would fluckuate?! Right?
Old May 30, 2010 | 01:37 PM
95DC2GS-R's Avatar
You need a GSR/ITR water pump with the 22T gear.
The LS water pump has a 19 tooth gear which makes the pump spin faster, at higher rpm it cavitates and makes air pockets in the coolant passages.
Bottom line, you're going to have to change the water pump with the correct one along with a GSR/ITR timing belt.
niceprelude
Feb 15, 2009 10:20 PM
totsie7944
Oct 31, 2008 02:44 PM
snowblind7x
Sep 3, 2008 01:31 PM
inline976
Nov 16, 2004 10:54 AM
thaiphob
Oct 31, 2003 05:24 AM
