cam caps?
Old May 28, 2010 | 10:52 PM
insaneconceptz's Avatar
Default cam caps?
ok here goes, I had to get a new used gsr head for my drag car and i noticed that the newer head did not have any of the cam caps, so if figured i would use the set i have from the old head and i should be golden....... well not the case so i put the head together just like it would be on the car, with out the valves and springs, torqued everything to spec and rotated the cams with a wrench and they are bound up.. they are suppose to spin freely right? so i got a another bad head i had on the shelf and tried those caps and got the same thing..... so my question how do you know which caps will work or not? i did notice one head i have has a number 2 and another head i have has a number 1 on it.... i did notice that the caps have a -1 and -2. does this number mean anything? how do i know what cam caps are going to work?
thanks
jereme
Old May 29, 2010 | 03:32 AM
NJIN BUILDR's Avatar
Default Re: cam caps?
At the factory the caps are installed on the head and then bored.This means the caps and head need to be kept as a set.If you use different caps they need to be align bored to be correct.Sometimes you can get lucky and a few caps will line up,but rarely will a full set.The numbers on the caps is the order from cam gear end to distributor.
Old May 29, 2010 | 03:30 PM
honda_luvr_2000's Avatar
Bingo.
Old May 29, 2010 | 05:10 PM
nsxter's Avatar
whats funny is he gives a special thanks to "Shannon aka Badway and Tom at Pac West for building me a solid track car...534whp/347torque" but he cant think to give them a call about his question
92bseries
Mar 23, 2010 04:20 AM
gutted-dx
Dec 23, 2008 07:26 PM
crispy93
Mar 8, 2007 07:17 PM
b20turboic
Nov 9, 2006 12:38 PM
rorik
Jan 20, 2006 08:54 PM
