Need big time advice on what to do with these rims ( pics included )
Hi guys, I have these rims sitting around
They are from my old sti and I cant seem to sell them for the life of me !! ( strange I know...I thought they would be gone in a day )
but regardless, what options do I have?
Right now, I belive the clearance hole is too small for the hub, so I would need to get it machined. - what will this cost?
and all the rims are 18*9 all around...............currently has 245/40 R18s on all 4
how will this fit what will I need to change? and will it even look good on a silverstone s2000? - keep in mind the sti sticker has been removed.
what problems will I run into running this on all 4?
I personally would not put a factory wheel off of on car onto another I would continue to try to sell those and buy something more suited for a S2...Good luck..........
if you do plan on getting the bore of the wheels machined to fit the s2k, keep in mind it has 2 different hub sizes, front and back. 70.7mm front/ 64.1mm rear I believe. also scoobie wheels are a 5-100 bolt pattern (unless its off the "05+ model, which it would be 114.3), honda is a 5-114.3 sooooo...
bottom line, its not worth it dude
i thought the subi wheels have really high (more than s2k factory) offsets also? sunken in wheels ftl?
like someone else said, if you haven't sold them, you must be asking too much.
specscow
Feb 1, 2006 04:46 PM
