major itr issues
Old May 28, 2010 | 11:31 AM
tweatybird74's Avatar
Default major itr issues
please help
i have a nuts and bolts rattling sound underneath when steping on the gas and especially starting off from a stop. i have checked the heat sheilds under neath and that is not it. what could this be please help
Old May 28, 2010 | 11:46 AM
00-1065's Avatar
Default Re: major itr issues
Either the cat converter or the resonator on the B pipe has gone bad from the inside and creates the annoying rattle. Very common on Civics and Tegs.
Old May 28, 2010 | 11:47 AM
no this rattling is coming directly from the motor could it be the engine mounts and one is broken ????
Old May 28, 2010 | 11:58 AM
00-1065's Avatar
Check if the bolts that hold the oil cooler to the block or the header bracket are tight or have come off.
Best way is to raise the car on jackstands or on a shop lift and check under it while someone is reving the engine to create the rattle.
Old May 28, 2010 | 12:11 PM
LankorDie's Avatar
Loved
Community Favorite
This is correct.
Check every bolt in the affected area to make sure they are tight. It could be a large number of things.
Old May 28, 2010 | 12:28 PM
The weird thing is that it doesnt do it at idle when i rev it. its when i start off when letting up the clutch i hear a terrible nuts and bolts rattle and when im driving every so often when i give it gas
Old Jun 1, 2010 | 10:01 AM
Tyrant_007's Avatar
Hopefully the flywheel bolts were all torqued properly. One of my buddies had his clutch installed and flywheel resurfaced. When installed one of the flywheel bolts backed out and made a $hitty noise.
tweatybird74
May 17, 2010 01:29 PM
Redprelude98
Jan 1, 2009 02:31 PM
anht
Sep 6, 2005 02:33 PM
1995H23Lude
Nov 30, 2004 10:11 AM
Nizzy
Welding / Fabrication
Aug 16, 2004 11:55 PM
