Suspension & Brakes Theory, alignment, spring rates....
Caster issue on a EJ2
Old May 28, 2010 | 09:59 AM
90efhatch's Avatar
Default Caster issue on a EJ2
I just bought the rims and tires on the car, once I put them on the passenger right front is rubbing the fender liner. I looked under the car and I do not see any way to adjust the caster. I am not sure what I need to do to fix this. I also looked into a traction bar to pull the wheel forward but dont see how with the setup on this model.
Any advice? I am headed to the local salvage yard hopefully tonight or in the morning to get the mount and the 2 lower arms and replace them to see if that helps.
Pic.
You can see the tire really close to the back of the fender on the front.
Old May 29, 2010 | 10:50 AM
90efhatch's Avatar
Default Re: Caster issue on a EJ2
I got the new lower control arms and that mount that the back part of the lower control arm bolts too. It fixed the issue, I figured I would post the fix in case someone has the same issue one day.
wdissident
13
Aug 16, 2021 02:56 AM
usdm_ED7
Dec 19, 2010 10:00 PM
CobaltInfinity
May 9, 2005 09:09 PM
CobaltInfinity
May 8, 2005 08:44 PM
