Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Installed my Sportlines and now hearing Metal clicking Noises...HELP!!!!!
Old May 27, 2010 | 08:13 PM
EnvyMySi's Avatar
Icon6 Installed my Sportlines and now hearing Metal clicking Noises...HELP!!!!!
So i own a Civic Si 4dr this car has 18k miles on it and i finally decided to drop it on sportlines.....I did the install myself with the help of a fellow 8th/friend Vingavina and we followed all the DIY guidelines on the DIY forums...
Since the install i have been hearing Metal clicking noise when i hit a dip or a small pothole as if two metal plates were hitting each other and not only does it sound annoying but its freaking me out because im scarred something may be loose...
i took pictures of my install if you guys know anything that may help my problem please lmk....THANKS!!!!
Old May 27, 2010 | 09:40 PM
T3KNiQe's Avatar
Default Re: Installed my Sportlines and now hearing Metal clicking Noises...HELP!!!!!
Spring didn't seat properally in the strut mounts, also the diameter of the spring is smaller compared to oem which can cause it to travel in the oem mounts. Just double check your 6 nuts for peace of mind, actually torque them to specs.
It's not gonna fall off the car or anything, I wouldn't worry to much. I'm just lazy.
Old May 27, 2010 | 10:21 PM
EnvyMySi's Avatar
thanks should i take em off and reinstall then??
EnvyMySi's Avatar
ohh and what would specs be for torque?? 30 lbs?
Old May 28, 2010 | 02:27 PM
09 civic si's Avatar
are you sure you got the right springs...
because the look weird to me....
i believe the spring its not sitting right on the strut.(bottom part).
double check that and make sure the springs are for an SI model
if its an SI....
Old May 28, 2010 | 03:53 PM
EnvyMySi's Avatar
Well the springs I bought em off a owner of a 2009 si
Old May 28, 2010 | 04:16 PM
i-VTEC_DOHC's Avatar
are the springs supposed to look crooked like that? my old sportlines didnt look like that
Old May 28, 2010 | 06:15 PM
Soccerking3000's Avatar
they arent crooked, thats jsut the dust cover for the shock, because the lowering springs are shorter than the stock ones its causes the dust cover to bend slightly. Thats why it looks bent.
Old May 28, 2010 | 09:38 PM
i dont know men...
but they dont look normal to me...
Old May 30, 2010 | 07:06 AM
EnvyMySi's Avatar
idk to me the second pic the rubber on top looks a bit squished....is it just me??
Old May 30, 2010 | 08:05 AM
02 accord's Avatar
The number on the springs should be 4.3140. What's yours?
Old Jun 20, 2010 | 03:02 PM
EnvyMySi's Avatar
The number is fine
bopbop93030
Suspension & Brakes
18
Apr 22, 2010 10:21 AM
wytetrashed
Sep 3, 2009 10:50 PM
alscrx
Honda Civic (2001 - 2005)
22
Jul 8, 2008 02:46 PM
raresi99
Nov 27, 2003 05:04 PM
ingrate
Aug 17, 2001 06:07 AM
