Gt40r compressor cover seal?
Old May 27, 2010 | 07:49 PM
TommyC83's Avatar
Default Gt40r compressor cover seal?
Was wondering if the precision gt4067r is supposed to have a seal between the compressor cover and backing plate. I called precision and they sent me seals for the center section. Before I call them back I want to see if there is even a seal on it or not as I've seen some turbos with it and some without.
Thanks for any help
Tommy
Old May 27, 2010 | 09:03 PM
Slow_boost's Avatar
Default Re: Gt40r compressor cover seal?
Check the packing plate and see if there is a grove around the circumference of the plate where a seal would be. If there is a machined groove, that is where the seal would rest. This will tell you if youlll need one.
Old May 28, 2010 | 08:42 PM
TommyC83's Avatar
There is the machined groove around the outter edge is this what you are refering to?
Old May 28, 2010 | 11:15 PM
t66crx's Avatar
nope you dont need one
its mostly on turbos for a carb before the turbo setup
Old May 28, 2010 | 11:30 PM
Slow_boost's Avatar
If there is a machined slot where the black line is around the circumference of your backing plate, that is where the seal goes and thus you would need one.
Edit: In my posted picture of my turbonetics unit, I do not need a seal. My precision 3071r does require one though. I dont know if thats just something that Precision does on their turbos or if it has to do with certain applications/ turbo or comp housing sizes.
Old May 29, 2010 | 03:43 AM
TommyC83's Avatar
Thanks for the info guys it's much appreciated.
93grayeg
Feb 18, 2013 10:12 PM
turbo boost
Feb 16, 2009 10:44 AM
wade
Jan 21, 2009 01:09 PM
wade
Jan 20, 2009 01:16 PM
