fuel gauge help
Old May 27, 2010 | 06:05 PM
79powerwagon's Avatar
Default fuel gauge help
hey, im new to this site and have a problem. i just bought a 90 crx with an aftermarket fuel pump and the gas guage does not work the pump is a 3 wire setup but the original is a 4 wire. what do i need to do/get to get the guage woking? any help would be much appreciated.
Old May 28, 2010 | 10:37 AM
dcraige's Avatar
Default Re: fuel gauge help
The fuel guage sending unit is seperate from the fuel pump. Its located under the rear storage compartment. You can use a jumper wire to test the guage in your dash and a multimeter to check the sender. Also make sure no fuses are blown.
Old May 28, 2010 | 05:27 PM
k thanks ill give it a try
Old May 29, 2010 | 09:54 AM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
See:
http://www.tboekholt.com/HondaCRX_Wo...s/91-23-95.jpg
http://www.tboekholt.com/HondaCRX_Wo...s/91-23-96.jpg
Old Jun 2, 2010 | 06:10 PM
well i got it working there was glue on the needle when the white faces were put on, but the only problem now is i broke the needle off putting it all back together any one know where i can get a new fuel gauge or a used one the works
Old Jun 2, 2010 | 06:44 PM
dcraige's Avatar
There are at least 5 guage clusters on eBay right now. Or look/post in the wanted/for sale section.
Vates
Apr 22, 2014 05:04 PM
Robotn1x
Sep 5, 2012 03:58 PM
thatHEMIguy
Apr 1, 2011 05:01 PM
criticalperformancejc
Feb 3, 2009 06:05 AM
redpeppers
Oct 3, 2005 08:53 PM
