DPFI to zc sohc swap (wiring)
I will be using the pm6 ecu for the swap.
I have a 1990 base model civic 5 speed, installing a zc sohc no vtec. I want to know if the easiest way to do the wiring is to get a SI harness?
When comparing my harness to the cut harness it looks like the plugs that go to the distributor don't connect.
Am I supposed to ditch the cut harness that's on there, if so what about the injector plugs?
Anybody have a link to a decent swap writeup for a DPFI equipped civic to a zc?
use the stock dpfi harness and convert it. although it would save time, you can't just plug in an si engine harness and go.
http://hondaswap.com/swap-articles/d...writeup-49557/
JibOnALib
Dec 18, 2005 10:33 AM
