92 honda prelude
Old May 27, 2010 | 01:04 PM
young_tuner's Avatar
Default 92 honda prelude
ok guys i got rid of my 97 i was to far in debt and wanted to get out. But i just found a 92 prelude si 5 spd for 1200. It has a clean title, and from the pictures i've seen it is a very clean prelude. It has 270,xxx miles though, thats the only thing that worries me, also he said the a/c doesn't work.. but that's not a big deal at the moment, i can always roll down the windows. What should i look for? What should i do before i decide to buy the car? Any common problems i should look for? Thanks in advance.
Thanks,
Ian
Old May 27, 2010 | 02:48 PM
BDM's Avatar
BDM
Default Re: 92 honda prelude
My 92 si has the same amount of miles and doesn't have a problem...I say go for it! Dropped a JDM H22 and new suspension in it and love it. 8)
Old May 27, 2010 | 05:20 PM
sweet, what does that swap run though..?
Old May 27, 2010 | 07:07 PM
95ludeVTEC's Avatar
alot better then the h23 but depending on whats done to it, it will be quick
Old May 27, 2010 | 07:12 PM
What do you think about the mileage though? Anything to look for?
Old May 28, 2010 | 02:44 PM
duanes's Avatar
I've got one JUST like it. 93, with H23A1 and Auto with 260K.
Works pretty good, but ABS light is always on (ABS pump is seized) and the car has seen more air time than a skateboard at the X-games! The only major problem is that it burns A LOT of oil as I have to add one quart for every fill up. Even at that, I get 23mpg and it runs well.
I am getting ready to overhaul or replace the engine. I really don't want to try to change to a manual and get all the linkage setup, so it really doesn't make sense to change to an H or F22. I think I'm going to help my son (15) rebuild the motor.
BTW: The AC works well on mine, but it needs a new heater valve to shut off the hot water going to the heater core in the summer.
Old May 29, 2010 | 12:42 AM
b-skizzle's Avatar
see if they have any maintenance records also look for any leaks, funny noises, but remember the H series valves are kinda loud. Check all the fluids make sure theirs no water in the oil vice versa and make sure it doesn't smoke.
Old May 30, 2010 | 01:31 PM
duanes's Avatar
I second the smoke. Smoke means that you are getting near an overhaul. Not a bad thing if you want to work on the engine, but something to be aware of.
hondaprelude"23
Aug 17, 2013 04:20 PM
brodyl05
Mar 20, 2007 08:21 PM
liam
Jul 8, 2006 01:35 PM
Fajin
May 27, 2004 02:06 PM
