RWD 4link with Strange Double Adjustable Spring???
Old May 27, 2010 | 11:44 AM
HickamHatch's Avatar
Default RWD 4link with Strange Double Adjustable Spring???
Have a project that will be RWD and 4 link and using the Strange Double Adjustable Coilovers. Car will weigh about 2300-2400 lbs when done and dont know which spring rate to go with in the rear. Can anyone shed some light on which springs to choose?
thanks
Old May 28, 2010 | 07:26 AM
s2kfromhell's Avatar
Pretty-n-Pink
Default Re: RWD 4link with Strange Double Adjustable Spring???
thanks
You want the strange s5006 with a 12/110 inch spring
Old May 28, 2010 | 07:31 AM
Thanks! I was close with thinking the 12/100 would be good. I will go with your advise though
Old May 28, 2010 | 10:48 AM
hyboost's Avatar
at 2300-2400 presuming the car is 50/50 then a 110 may still be lite. if the car is on a big tire or small tire in will make a differance in how the car will take the hit. i had changed springs 5 times to find the right one for my car. it's 2552 with me in it and i have a 130 spring on Radials. with a nice shock set-up. you will have a lot of playing around with the shock to get it just right.
what kind of car and chassis setup is it?
Old May 28, 2010 | 11:02 AM
92 Civic hatch. New floor from firewall back. Ford 9". K24 with 67mm turbo.
Old May 28, 2010 | 12:21 PM
hyboost's Avatar
Is it 3/4 chassis or full chassis? And 1 word BADASS
Whats the ETA on it?
Old May 28, 2010 | 12:28 PM
Well nscra rules say that I will only be able to run back half if it is rwd to be in the hot rod class. So the full floor might be out of the picture. I amm hoping to be done by 2011 when nscra comes to Texas.
Old May 28, 2010 | 05:48 PM
hyboost's Avatar
YOU HAVE ANY PICS?
Old May 28, 2010 | 06:00 PM
k
Old May 28, 2010 | 06:12 PM
hyboost's Avatar
what tranny? is it just a 6 point now?
Old May 28, 2010 | 06:18 PM
T56. I used manual instead of auto cause I plan on driving it on the street and won't be a track only car. Yes it only has a 6pt in it right now. I am about to do my cage as soon as I get my pipe bender. Already have the chromoly.
Old May 28, 2010 | 06:37 PM
hyboost's Avatar
when your ready call brandon at liberty and he can set you up with and nice gear set for the T56.
Old May 28, 2010 | 06:51 PM
SPOOLINmatt's Avatar
on the street really?.............REALLY?
Old May 28, 2010 | 08:08 PM
Thanks hyboost
Old May 30, 2010 | 12:21 AM
ScorpioMk's Avatar
whats the plan to mate that trans to the motor? i want a t56 behind my f20 before i start blowing up transmissions.
jdmhatch1
Suspension & Brakes
17
Feb 27, 2009 06:54 AM
Misf1t
Suspension & Brakes
Nov 30, 2007 07:03 PM
EJ8 Kenobi
Suspension & Brakes
12
Jun 1, 2007 06:05 AM
4door
Suspension & Brakes
Sep 15, 2005 05:06 AM
MrBite
Dec 9, 2001 09:09 AM
