Speedometer in '95 EX coupé not working
Old May 27, 2010 | 11:29 AM
filipetolhuizen's Avatar
Default Speedometer in '95 EX coupé not working
Greetings to all,
I just purchased a 3rd hand Accord '95 EX coupé and the previous owner told me to replace the speed sensor for the speedometer to work. I did it already but it still isn't working. The whole dashboard was replaced by the previous owner due to a failure in the fuel meter and a crack on the plastic cover, but he also gave me that. If I put the original back in would the speedometer start working again or is this anything else I should be aware of? Is there anywhere that I can access a full chart of the F22B1 SOHC VTEC engine? I would like to know every detail about it so I can be aware of anything that comes up.
Cheers,
Filipe
Old May 27, 2010 | 05:46 PM
davey5300's Avatar
Default Re: Speedometer in '95 EX coupé not working
is the check engine light on? if it is then check the code to see if it's the speed sensor code. if it's not on, the the speedometer itself is bad. you can do one of two things:
A: switch the speedometer from the old cluster to the new cluster
B: switch the fuel gauge from the new cluster to the old one and re-use the old one
Old May 27, 2010 | 05:49 PM
Yes, the engine light is always on.
Old May 27, 2010 | 06:11 PM
davey5300's Avatar
you'll need to find out what the code is first. it could be the Speed sensor code
Old May 27, 2010 | 06:12 PM
I already tried replacing it but still didn't work.
Old May 27, 2010 | 06:21 PM
TheMuffinMan's Avatar
He knows where you live!
I don't know why common sense doesn't prevail.
The Check Engine Light is on for a reason, scan for the CEL and find out what code it's there for. If it is in fact the VSS and you had replaced it with a used one or random eBay branded one I would wager that is the problem.
As to knowing every detail you need to purchase a Helms manual and thumb through the Accord FAQ
Old May 27, 2010 | 06:26 PM
Anyways, I'm taking it to a specialist tomorrow as there are still tons of things to get sorted out and this is just the beginning. I'll let you know if I find something.
Old May 27, 2010 | 06:37 PM
https://honda-tech.com/forums/honda-accord-1990-2002-2/check-engine-light-codes-cel-diagnostic-trouble-codes-dtc-malfunction-indicator-light-mil-1490107/
From the Accord FAQ, you are OBDI but similar will apply.......
You can do a search if you need pictures for the 2 pin service connector on the passenger side behind the glove box.
Along with how to take apart the dash and everything else you could think of.
Old May 27, 2010 | 07:35 PM
It seems that the information on this faq is for the models after 1996. Mine is a 1995. Does it still apply? How can I get that diagnose tool?
Old May 28, 2010 | 03:28 AM
As I said, you are OBDI but can use it as a reference.
A paperclip is your diagnostic tool.
https://honda-tech.com/forums/honda-accord-1990-2002-2/check-engine-light-96-honda-accord-ex-2703528/
http://www.instructables.com/id/How-...gine-Light-Fo/
The second link is even FOR a 95 Accord.
And another thread found from searching in the Accord section
https://honda-tech.com/forums/honda-accord-1990-2002-2/90-93-accord-obd1-cel-codes-2630683/
_EF9
Apr 21, 2013 09:59 AM
4LugHero
Jul 11, 2012 06:21 PM
RTE117
Apr 22, 2009 09:52 AM
Xtian8
14
Jul 28, 2005 09:00 PM
