vtec solenoid issues
Old May 27, 2010 | 11:21 AM
jpstaff89's Avatar
Default vtec solenoid issues
solenoid has been leaking for about a week now and i've gone through 3 gaskets. its getting annoying. i'm not throwing any codes. can i get some help?
Old May 27, 2010 | 12:00 PM
rustanghunter's Avatar
Default Re: vtec solenoid issues
why would leaky solenoid throw a code? post a picture or be more specific
Old May 27, 2010 | 02:01 PM
jpstaff89's Avatar
it would throw a code if it was the oil press sensor or spool valve. no codes and if its not electrical its a mechanical issue and i can't pinpoint it.
Old May 27, 2010 | 09:39 PM
jpstaff89's Avatar
and to be even more specific at the top of third gear about 7500 vtec kicks out/ sometime fuel cut and this doesnt happen in any other gear. oil will run out from the vtec solenoid gasket at warm up but only about 10 seconds or so. more or less it leaks intermittently after it decides to ruin gasket after gasket.
Old Jun 18, 2010 | 06:31 AM
jpstaff89's Avatar
nobody's got anything for me? sweet
Old Jun 18, 2010 | 08:00 AM
crx_si-r's Avatar
are you using the correct gasket? what kind of solenoid? jdm obd0, obd1 or obd2??? you might be using the wrong gasket. or you might need to replace the other gasket.
Old Jun 30, 2010 | 11:34 AM
Woodlock's Avatar
my solenoid on my 97 gsr is doing the exact same thing.......... its my second gasket and im wondering WTF??
Old Jul 1, 2010 | 12:34 PM
jpstaff89's Avatar
alright. so i figured it out. the oil was too thick. and i'm currently using an obd0 off an integra xsi. so far 800 leak free miles. and i use the 99-00 si gasket.
Old Jul 6, 2010 | 10:58 AM
jpstaff89's Avatar
it is still occasionally popping in and out at high rpms so i'm kaking sure a my connections are solid. if that doenst help im gonna switch out the ecu clips on the body harness
Old Jul 6, 2010 | 01:13 PM
gringo7718's Avatar
If only you would learn to search. It is in the FAQ at the top of the page and has been covered many times.
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/diy-crx-jdm-b16-vtec-solenoid-gasket-change-2173498/
Old Jul 8, 2010 | 08:30 AM
jpstaff89's Avatar
thanks for the link
rpk1002
20
Dec 9, 2011 01:21 PM
Elvis1977
Oct 7, 2010 07:00 PM
Moi Zver' (GSR)
Dec 3, 2009 01:17 PM
Lightsped
Sep 1, 2009 08:40 AM
I got a honda
Aug 28, 2005 11:37 PM
