Help! Fuel pump not priming!
Hey so i just completed my b16a swap in my eg hatch and I started it today and let it run on idle and get up to temp. runs very good. turned off the car to answer a phone call and afterwards went back to start the car and i get nothing coming from the fuel pump when the key is on, cant hear it kick on or anything, i checked the fuse and its still a good lookin 20A fuse, why could it all of a sudden not want to kick on!?! Any replies help, im stumped. thank you.
If not the Main Relay check the actual pump make sure its getting the required voltage if its aftermarket it may require 13.5v instead of the stock 12v pump. if its not that check the ACG(S) Fuse under the dash should be a 15amp car sounds like normal but fuel pump doesnt prime at all.
SPUNKYMUNKY
11
Mar 27, 2015 03:58 PM
electron_si
Feb 18, 2008 08:17 AM
