Pressure Plate and clutch install
I had just purchased a clutch kit. I was wondering is this normal ? I cant seem to bolt my clutch onto my engine. I feel that if i keep screwing the pressure plate bolts i would crush the disc.
With clutch disc / pressure plate on flywheel
Without clutch disc / just pressure plate on flywheel
Pressure plate fins protruding outwards.
Thickness of clutch disc off of flywheel on top of pressure plate.
I found this thread, but didnt find any answers.
https://honda-tech.com/forums/showth...pressure+plate
Well you have to tighten the pressure plate to the point that the fins are "flat." Does the clutch fit inside the pressure plate? Where did you buy the kit? And what brand is it?
You may also need a stepped flywheel to fit all that in there, was there any indication of requiring a stepped flywheel setup when you purchased the kit?
I purchased the clutch from thmotorsports. I have pmed and emailed them already.
The clutch kit i purchased is an exedy khc05.
This is what i found on the exedy website.
KHC13 1997 - 1998 INTEGRA TYPE-R L4; 1.8L; Non-Turbo; Gas(B18C5)
KHC12 2000 - 2001 INTEGRA TYPE-R L4; 1.8L; Non-Turbo; Gas(B18C5)
KHC12 2000 - 2001 INTEGRA GSR L4; 1.8L; Non-Turbo; Gas(B18C1)
KHC05 1994 - 1999 INTEGRA GSR L4; 1.8L; Non-Turbo; Gas(B18C1)
below are identical with respect to their specifications (Disc outer diameter / Spline teeth).
Part Number: KHC12
Part Number: KHC05
Disc Outer Diameter 219mm(8-5/8in)
Spline Teeth / Major Diameter 24T / 1-1/16in
I did notice that for Part Number: KHC13 the specifications are listed below.
Disc Outer Diameter 210mm(8-1/4in)
Is the disc outer diameter referencing to the overall diameter of the clutch or pressure plate? or is it measuring the depth of the pressure plate?
As you mentioned I feel that if i keep screwing on the bolts that I will crush the clutch disc and will have to buy another clutch disc. As I screw the pressure plate bolts it appears theres already load against the pressure plate and clutch disc. It would be tricky to get the pressure plate centered evenly to sandwich the clutch disc.
I feel that if i have a stepped flywheel I would not be able to thread in the pressure plate bolts.
My current flywheel is an ITR with gsr tranny.
It was my error. Clutch fits. I just had to tighten pressure plate bolts. The instructions did mentioned that the fingers should be flat instead of protruding. As i tightened the bolts t he fingers became flat. The instructions indicated the fingers should of been flat when installing. I guess from factory the fingers were protruding instead of flat.
SuicideSlide
11
Aug 29, 2004 01:25 PM
Just Checking In
Mar 27, 2003 09:41 PM
