b18a1 on a EG WONT STAY ON
Old May 26, 2010 | 05:41 PM
viera's Avatar
Default b18a1 on a EG WONT STAY ON
this is my first swap everything looks ok, but the car wont stay on only if i keep the gas pedal down and as soon i let go it shut off. any idea? any help would be appreciated.
also im using the old obd1 lx ecu. could that be the problem?
Old May 26, 2010 | 09:48 PM
honda_luvr_2000's Avatar
Default Re: b18a1 on a EG WONT STAY ON
Double check that your TPS & MAP sensor plugs aren't switched, and your IAT, IAC, & PCS (Purge valve) plugs aren't mixed up. It happens. Have you tried adjusting the idle? Set base ignition timing? Adjusted distributor timing? Checked for vacuum leaks?
Old May 27, 2010 | 07:57 AM
viera's Avatar
thanks for the reply. I'll check the plugs when I get home today. I can't adjust the idle on the TB do to is an aftermaket one and it doesn't have the adjustment screw on it.
PavPerformance
Jun 5, 2015 08:11 AM
ElswickB22
Oct 13, 2013 02:33 PM
allmotorgsrekk
16
Mar 27, 2010 07:30 PM
Stoich
28
Jul 5, 2005 09:29 PM
ogwutang
May 5, 2003 05:36 PM
