injector problems
Old May 26, 2010 | 04:24 PM
bradennicely's Avatar
Icon6 injector problems
i posted in ef thread but no one seemed to help
90 crx dx jdm b18b converted to obd1 injectors are still obd0 (still have resistor box)
i did a wire tuck and fixed the half a$$ mpfi swap
now when i start my car is idles funny and simply doesnt run right.
smokes when you give it alot of gas
you can smell fuel real strong in the bay (no leaks)
its throwing code 16 (fuel injectors)
the only thing i can think of is something is grounding our the injectors and is constantly spraying fuel
anyone every had this problem?
thanks ahead for the help
Old May 26, 2010 | 06:47 PM
gstrudler's Avatar
Default Re: injector problems
What are you tuning it with? Getting your AFR's measured would be the fastest way to figure out where you stand. Also would recommend pulling your spark plugs and check to make sure none of them are covered in fuel (as in one of the cylinders isn't firing).
Old May 28, 2010 | 07:47 AM
not tuning it at all, completely stock.. it just seems its getting tooo much fuel
elmalouno
38
Apr 18, 2019 03:18 PM
bradennicely
13
May 26, 2010 04:36 PM
integraracing91
Aug 6, 2004 07:34 AM
racerboyb18c
Jan 9, 2003 01:30 PM
