Where can I get a flywheel cover?
Old May 26, 2010 | 03:14 PM
EJeff8's Avatar
Default Where can I get a flywheel cover?
Just noticed my car doesn't have one and I assume it's why it sounds like I have terrible brakes everytime I downshift (it's annoying when everyone goes man your brakes are bad, when I never hit the pedal). Where can I just find an OEM one? Honda?
Also, I popped in a knock sensor today on my Y8. I got the ECU cleared but no VTEC. I ran it to third to try and the light came back on, I haven't ran back to autozone since then so I don't know if the CEL is still for the sensor or the other code that was on. The sensor isn't butt to butt to the block persay, there's about 2 to 3 mm of thread still sticking out due to it only being hand tightened. Is it still too far out?? I plan to pop off the mani and tighten it Friday. Will that fix VTEC? Only other code was an idle manlfunc.
Appriciate the help!
Old May 26, 2010 | 03:24 PM
shawn_crx's Avatar
Default Re: Where can I get a flywheel cover?
dealer.. or junk yard.
Old May 26, 2010 | 03:58 PM
mooze's Avatar
my house
Old May 26, 2010 | 04:02 PM
EJeff8's Avatar
Oh haha. The Y7 flywheel cover will bolt right up right? That's the only one's at the clostest yard to me. You guys have any answers about my sensor?
Old May 26, 2010 | 04:35 PM
98civdx's Avatar
Master Detailer
honda.
use the jumper method to check the cels. IT's at the top of the page check it out.
Old May 26, 2010 | 04:56 PM
BryanM.'s Avatar
Resident Gearhead
You can get the clutch case cover aka "inspection plate" at a salvage yard or an online salvage yard network, Honda dealer, or you can find one for sale right here on H-T from someone who is too baller to use it.
Old May 26, 2010 | 06:46 PM
EJeff8's Avatar
Alright thanks! Any idea about my sensor? Does it have to be tight to the block to work? I had a helluva time getting it to where it is now without taking things apart
Old May 26, 2010 | 06:59 PM
ca-rs's Avatar
What engine/trans do you need the cover for? I may have one laying around.
Old May 27, 2010 | 03:10 AM
BryanM.'s Avatar
Resident Gearhead
You can get to the knock sensor from underneath the car, it's a bit of a pain to do but it's much easier and faster than removing the intake manifold. Removing the oil filter will give you more room iirc.
And I will never understand why people don't use those covers. I guess they want **** to get in there.
Old May 27, 2010 | 11:11 AM
EJeff8's Avatar
Yeah, I tried that with a 1/2 socket wrench and it was a bitch to be under the pan, I did see I was missing the plate which was good. I thought the port was right beside the filter and my heart dropped when the sensor was too small. I then researched and then found the damn hole right under the 3rd runner. I tried both methods of above the car and under but left about 3 mm out of the hole. Is it still too far for the ECU to recognize it? And just popping the bolts off the mani from the block will allow me to just move it back and get to the sensor. Maybe a 1 to 2 hour job on a Friday afternoon. I just really want VTEC. Also, it's a y7/y8 mini me with the 5 speed Ex tranny
john'sD16Aek
15
May 1, 2013 02:25 PM
gogolf0401
Sep 28, 2012 08:43 AM
89LSED
Jan 13, 2011 08:05 PM
illestrolla247
Aug 13, 2004 06:52 PM
stephenB!
Mar 12, 2004 06:33 AM
