Suspension & Brakes Theory, alignment, spring rates....
NA1 NSX caliper rebuild
Old May 26, 2010 | 02:35 PM
Blazin Si's Avatar
Loved
Community Favorite
Default NA1 NSX caliper rebuild
I have a bare core for the drivers side caliper. Where can I find the parts to rebuild it? Rockauto.com sells some of the parts, the rest will need to be sourced from another supplier.
Thanks
Old May 30, 2010 | 05:00 PM
roastbeefrichie's Avatar
Default Re: NA1 NSX caliper rebuild
http://www.acuraoemparts.com/delray/...All&vinsrch=no
* 1 6 C L 1 5 V N ~ 2 8 T *
* Illustration No. * Part Number * Description * (Required Qty.) * Price *
002 43352-SM4-003 SCREW, BLEEDER (X2) $4.68
003 43353-SD5-003 CAP, BLEEDER SCREW (X2) $2.92
004 44200-SL0-008 BEARING ASSY., FR. HUB UNIT (X2) $183.98
005 44304-SL0-000 CAP, FR. HUB (X2) $10.82
006 44353-SL0-000 PULSER, FR. (X2) $109.45
007 44600-SL0-020 HUB, FR. AXLE (X2) $200.53
010 45022-SL0-030 PAD SET, FR. (16CL-15VN,NS145H) (X1) $206.15
011 45210-SL0-023 CALIPER ASSY., R. (16CL-15VN28T) (NISSIN) (X1) $792.52
012 45213-SL0-003 PISTON (36MM) (X2) $73.82
013 45214-SL0-003 BOOT, PISTON (36MM) (X2) $16.57
014 45215-SL0-003 BOOT, PISTON (40MM) (X2) $16.57
015 45216-SL0-003 PISTON (40MM) (X2) $73.82
016 45217-SL0-003 SEAL, PISTON (36MM) (X2) $20.80
017 45218-SL0-003 SEAL, PISTON (40MM) (X2) $28.85
018 45225-SL0-003 SHIM A (INNER) (X2) $8.35
019 45226-SL0-003 SHIM B (INNER) (X2) $8.35
020 45227-SL0-013 SPRING, PAD (X2) $16.53
021 45228-SL0-003 SHIM, PAD (OUTER) (X2) $8.35
022 45230-SL0-023 CALIPER ASSY., L. (16CL-15VN28T) (NISSIN) (X1) $914.13
023 45234-SM4-003 BOOT, PIN (X4) $7.88
024 45235-SL0-003 PIN A (X2) $13.67
025 45237-SL0-003 RETAINER (X4) $24.37
026 45240-SM4-003 BOLT, FLANGE (10X24) (X4) $3.90
027 45251-SL0-030 DISK, FR. BRAKE (X2) $179.15
030 45262-SL0-003 PIN B (X2) $13.50
031 90107-SL0-000 BOLT, CALIPER MOUNTING (X4) $4.88
032 90113-SD4-902 BOLT, WHEEL (SAGA) (X10) $4.37
033 90164-SL0-005 BOLT, FR. HUB UNIT (10X75) (X8) $7.93
034 90366-SP0-003 NUT, SPINDLE (X2) $14.08
035 90369-SL0-003 NUT, SELF-LOCK (10MM) (X8) $7.60
036 91352-SL0-003 O-RING (73X1.3) (X2) $2.70
037 93600-06014-0H SCREW, FLAT (6X14) (X4) $0.52
038 93893-06012-05 SCREW-WASHER (6X12) (X8) $0.80
Batoutahell
Apr 21, 2015 12:20 AM
fastshift
Nov 17, 2009 05:58 PM
propulsion1
Nov 16, 2004 06:18 AM
elnoyl
Jun 9, 2003 03:23 PM
