b20b rebuild kit???
Old May 26, 2010 | 02:30 PM
JCurry's Avatar
Default b20b rebuild kit???
well i just picked up a 91 hatch with a b20b swap in it. Im looking to go ahead and rebuild the engine because i dont trust what the guy told me about it. im not having any luck finding a rebuild kit for this motor online unless kits for other engines work with this one...i just wanna do re ring, bearings, and all the gaskets....also it has a ls head on it does that hurt the engine in any way?? is it worth the money to do arp rod bolts and head studs if i dont plan on boosting it or running n2o?
thanx
Old May 27, 2010 | 09:59 AM
JCurry's Avatar
Default Re: b20b rebuild kit???
anyone?
Old May 27, 2010 | 11:53 AM
rustanghunter's Avatar
ebay
Old May 27, 2010 | 01:33 PM
JCurry's Avatar
they have nothing ive tried searching all i can find is acl race bearing kits...
Old May 27, 2010 | 01:51 PM
89LSED's Avatar
The B20B comes with an LS head. They are the same thing.
Dont worry about the bolts. and B20/18 is the same gaskets for the most part
go OEM or Ebay.
I prefer OEM
Old May 28, 2010 | 09:30 AM
JCurry's Avatar
so i can buy a ls gasket set and most will fit? what about the water pump and oil pump? ive seen re ring sets and bearing sets on ebay but not a complete overhaul kit...
Old May 28, 2010 | 09:33 AM
KINGVEM^^ED6's Avatar
just buy another b20b
Old May 28, 2010 | 01:35 PM
JCurry's Avatar
ok ummmm ....no.. why would i buy another one when this one runs fine?? i just wanna rebuild it for peace of mind
Old May 28, 2010 | 03:48 PM
W/E ITS PROLLEEE GONNA COST THE SAME TO REBUILD IT BUY HEY GOOD LUCK
Old May 28, 2010 | 06:46 PM
JCurry's Avatar
hmm well at least if i rebuild it ill know the engine is good then not takin a chance on another used jdm engine....i found a re ring set for 45 bucks and a bearing set for 65 bucks but i cant find a gasket set but ill prob just buy the one for the ls and see what all fits...thanx for the help
another question tho will a gsr obd2 distributor running on the engine make it run weird like idle wise??? it ides funny and is throwing a code for it and dosent seem to have any power...its converted to obd1 at the ecu and is running a p75 ecu but has a obd0 to obd2 distributor jumper harness and is running the gsr dizzy...any advice??
Old May 29, 2010 | 09:36 AM
im pretty sure you need a obd1 dizzy
Old May 31, 2010 | 10:15 AM
JCurry's Avatar
ok well on ebay they have full master rebuild kit for the b20b4 and the b20z2...which one of these is gonna work right on my b20b?
jfral087
Mar 28, 2012 01:23 PM
nothing_shocking
Nov 19, 2010 08:25 PM
category5 SI
Mar 30, 2008 06:27 PM
unclematt
Oct 20, 2007 05:41 PM
01-0720
Feb 4, 2007 12:21 PM
