Difference in JDM ZC tranny and Si tranny
Old May 26, 2010 | 10:49 AM
StayKrafty's Avatar
Default Difference in JDM ZC tranny and Si tranny
Just like the title states, trying to figure out what tranny is in my car. Its an L3 but has LSD. I was doing some research on google and a site said that with the ZC tranny had to use integra axles. Is this true? Would a ZC bolt up to a JDM D15B? Or do I just have an Si tranny with aftermarket LSD? Also, difference in 88 and 89-91 crx si trannys? Just curious because I was looking for clutches and said will not fit 88 tranny.
Old May 26, 2010 | 12:27 PM
BiG ChOr!Zo's Avatar
Default Re: Difference in JDM ZC tranny and Si tranny
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/stock-clutch-fitment-guide-2284956/
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/what-look-identify-si-tranny-1551508/
http://tjshondas.20m.com/l3.htm
Old May 26, 2010 | 02:49 PM
StayKrafty's Avatar
Well that helps I don't have the zc because I have regular d series half shafts. Now on to figure out what year tranny I have
Old May 26, 2010 | 02:52 PM
Tyson's Avatar
what makes you think you have an LSD if the tranny is in the car?
Old May 26, 2010 | 03:12 PM
StayKrafty's Avatar
No obstical in the differental. Is that not a way to tell? Its clear all the way through.
Old May 26, 2010 | 06:35 PM
K2e2vin's Avatar
ZC has the same gear ratios as an Si, so it wouldn't matter.
If the transmission uses the intermediate shaft, it will not work with the D15B block unless you modify the axle(driver's side) or swap a "regular" differential in there.
88 transmissions have a different input-shaft spline count(the clutch itself is smaller diameter too).
What Tyson is trying to say is how do you know if the transmission is already in the car? Is it already in there or are you putting it in there?
Old May 26, 2010 | 08:23 PM
StayKrafty's Avatar
Had it off the car. And if the way to identify what year trans is right (the gold sticker) then I have an 88-89 trans. Now I need to figure out for sure which one I have.
Old May 26, 2010 | 10:32 PM
Icon_Ed6's Avatar
88= no ring on tip of input shaft 21-spline
89= 1 ring on tip of input shaft 20-spline
90-91= 2 rings on tip of input shaft 20-spline
Jus blew out my diff on friday so i went thru this AGAIN lookin for a tranny
Old May 26, 2010 | 10:34 PM
StayKrafty's Avatar
Haha no good man. I guess Ill just pull the tranny. Thanks for the help guys.
Old May 26, 2010 | 10:37 PM
Icon_Ed6's Avatar
I found this on H-T a log *** time ago
Old May 26, 2010 | 10:53 PM
Tyson's Avatar
ok, fair enough, you have a LSD if you can see right thru the differential with both axles removed. the "gold" L3 sticker means nothing. other than its a 88-91 tranny. nothing more. not "88-89".
you needed to look at the main shaft tip in order to know the year.
theres a stamping on the trannys that from what i read tell the year. but thats confusing and not always accurate from what i hear.
J I was doing some research on google and a site said that with the ZC tranny had to use integra axles. Is this true?
so are you using an intermediate shaft or not? if you are... then ok, you got a DOHC ZC tranny with a factory LSD. and you probably have DA integra axles installed to make it work anyway. regular SI axles wouldnt work with a DOHC ZC diff, it NEEDS the intermediate shaft.
if you arent.... then i dont trust anything ur saying. because i cant think of a non-intermediate shaft tranny that came with a OEM LSD.
giving you the benefit of the doubt. you got the intermediate shaft, right?
Old May 26, 2010 | 11:12 PM
StayKrafty's Avatar
No intermediate shaft. I got the car from a kid who bought it from some guy who worked at a tuning place. The kid I got it from knew nothing about the car so now I'm trying to figure it out. It may not have lsd, I could have been looking at it wrong. That's why I was curious about the zc trans because I two have never heard of a factory si trans with lsd. Plus, my first post said I think it may have aftermarket lsd, I never said it was OEM. I'm going to replace both half shafts so in the process I'll snap a pic.
(Civic_Duty)
Dec 10, 2005 02:17 PM
SwissChEz82
Oct 17, 2004 08:49 AM
dingusjt
Jul 1, 2003 02:56 PM
crxzc
Mar 29, 2002 07:57 AM
