Performance General Performance oriented Parts (Ex: Camshafts, Electronics, Air Intakes, Exhausts, complete engines)
Build Your B-Series Internal Master Price Sheet INEXPENSIVE COMBO PACKAGE DEALS!
Old May 26, 2010 | 10:36 AM
RealStreet's Avatar
Default Build Your B-Series Internal Master Price Sheet INEXPENSIVE COMBO PACKAGE DEALS!
Hello guys,
Our specialization here at Real Street Performance is engine building and the associated parts. We are not an accessory shop, there are far better places to buy your wings and your lips from, but if you need pistons, rods, valve springs, cams, turbos or anything that holds the engine together, helps make the power or helps get the power to the ground, we can probably help you.
I will list a lot of the parts we have for sale in this thread, if you need something that isnt shown here please PM me for an immediate response. OR please call us at 407-695-7223 and make sure to let us know you are from Honda-tech.com You can also IM us on AIM at RealStreetSales or on MSN with sales@realstreetperformance.com which is also our direct email.
www.RealStreetPerformance.com
Phone1: 407-695-7223
AIM: RealStreetSales
Email: Sales@RealStreetPerformance.com
MSN: Sales@RealStreetPerformance.com
Everything in this thread is specific to the B-Series Engines. As you guys know there is a ton of mix and matching for pistons etc so if you have specific questions about what the compression will be in your specific motor contact us directly.
I will start out with our very popular Piston/Rod Combos Starting from the least expensive. Make sure you ask us about package deasl!
PISTON/ROD COMBOS
SRP Forged Pistons with Eagle H Beam Rods $739.99
(Comes with Rings, Pins, and Locks -)
For B18C Bore Sizes and Compression Click Here
For B16 Bore Sizes and Compression Click Here
For B18 a/b/B20 Bore Sizes and Compression Click Here
Wiseco Forged Pistons with Eagle H Beam Rods $774.99
(Comes with Rings, Pins, and Locks Includes Skirt Coating)
CP Forged Pistons with Eagle H Beam Rods $794.99
(Comes with Rings, Pins, and Locks)
JE Forged Pistons with Eagle H Beam Rods $829.99
Wiseco Forged Pistons with Manley H Beam Rods $809.99
(Comes with Rings, Pins, and Locks/Skirt Coating Standard)
CP Forged Pistons with Manley H Beam Rods $834.99
Wiseco Forged Pistons with Brian Crower H Beam Rods $859.99
(Comes with Rings, Pins, and Locks -Coating Included)
For B16 Bore Sizes and Compression Contact Us
For B18 a/b/B20 Bore Sizes and Compression Contact us
CP Forged Pistons with Brian Crower H Beam Rods $899.99
Wiseco Forged Pistons with Manley I Beam Rods $1189.99
CP Forged Pistons with Manley I Beam Rods $1219.99
JE Forged Pistons with Manley I Beam Rods $1219.99
Wiseco Forged Pistons with Pauter X Beam Rods $1199.99
(Comes with Rings, Pins, and Locks With Coating-)
For B18 a/b/B20 Bore Sizes and Compression Contact Us
CP Forged Pistons with Pauter X Beam Rods $1219.99
JE Forged Pistons with Pauter X Beam Rods $1219.99
Pistons
Wiseco Forged Pistons - $499.99
(Comes with Rings, Pins, and Locks - Skirt Coating comes Standard)
SRP Forged Pistons - $479.99
CP Forged Pistons - $592.20 OR BEST OFFER!!!!!
JE Forged Pistons - $549
connecting Rods
Eagle H Beam Rods - $339.99
For B18C Click Here
For B16 Click Here
For B18 a/b/B20 Click Here
Manley H Beam Rods - $329.99
For B18C Click Here
Brian Crower H Beam Rods - $359.99
For B18C Click Here
For B16 Click Here
For B18 a/b/B20 B Call or email
Manley I Beam Rods - $739.99
For B18C Click Here
For B16 Click Here
Pauter X Beam Rods - $775
Carillo H Beam Rods with Carr Bolts- $1199
Head Gaskets
Cometic Headgasket - $99
Bearings
ACL RACE BEARING KIT- $149
Fasteners
ARP Head Studs - $140
ARP Main Studs - $100
Gates Racing Kevlar Timing Belts
Gates Racing Kevlar Race Timing Belt - $114.99
VTEC VALVETRAIN PARTS
Brian Crower Stage 2 Turbo VTEC Camshafts - $439.38
For B18C/B16 Click Here
Brian Crower Stage 2 VTEC Camshafts - $439.38
Brian Crower Stage 3 VTEC Camshafts - $439.38
Skunk2 Tuner Stage 1 VTEC Camshafts - $611.99
For Specs B18C/B16 Click Here
Skunk2 Tuner Stage 2 VTEC Camshafts - $611.99
Skunk2 Tuner Stage 3 VTEC Camshafts - $633.99
Skunk2 Pro Stage 2 VTEC Camshafts - $655.99
Skunk2 Pro Stage 3 VTEC Camshafts - $688.99
Brian Crower Dual Valve Springs and Titanium Retainers - $346.88
Supertech Dual Valve Springs and Titanium Retainers - $329.99
Skunk2 Tuner Dual Valve Springs and Titanium Retainers - $407.98
Skunk2 Pro Dual Valve Springs and Titanium Retainers - $514.98
Ferrea Dual Valve Springs and Titanium Retainers & Seats - $579
Ferrea 5000 Series Flat Valves- $199
Ferrea 6000 Series Valves- $249.99
Supertech Black Nitraded Stainless Steel Valves- $269.99
Brian CrowerBlack Nitraded Stainless Steel Valves- $286.88
Skunk2 Pro Series Stainless Steel Valves- $291.99
Skunk2 Pro Series Adjustable Cam Gears- $244.99
Supertech Bronze Valve Guides- $89.99
Supertech Valve Seals- $19.99
NON VTEC VALVETRAIN PARTS
Brian Crower Stage 2 Turbo Non-VTEC Camshafts - $323.75
For Specs Click Here
Brian Crower Stage 2 Non-VTEC Camshafts - $323.75
Brian Crower Stage 3 Non-VTEC Camshafts - $393.13
Brian Crower Dual Springs and Titanium Retainers - $323.75
Supertech Dual Springs and Titanium Retainers - $329.99
Ferrea 6000 Series Valves - $249.99
Supertech Black nitraded SS Valves - $269.99
Brian Crower SS Valves - $286
Old May 26, 2010 | 01:45 PM
RealStreet's Avatar
Default Re: Build Your B-Series Internal Master Price Sheet INEXPENSIVE COMBO PACKAGE DEALS!
Pms anwered thanks guys!
Old May 27, 2010 | 03:10 AM
RealStreet's Avatar
pms replied!
Old May 27, 2010 | 10:17 AM
RealStreet's Avatar
up!
Old May 27, 2010 | 08:11 PM
jpangeles's Avatar
Hi just sent email to u guys. Can i pls get a price quote shippez to 94555. I want the first package of the piston n rods combo. The srp piston and eagle rods. This combo package comes with arp rod bolt rite? Also pls add the arp head bolt and arp main bolt. My set up is lsvtec. B18 block with gsr head. Thnks much. Also my email add is jpangeles84@netzero.com
Old May 28, 2010 | 06:04 AM
RealStreet's Avatar
Yes sir the package includes the SRP Pistons with rings, pins, and locks along with the Eagle H Beam Rods with ARP 2000 3/8 rod bolts. I will PM you now
Old May 28, 2010 | 06:19 AM
Eg8Don's Avatar
bump
Old May 29, 2010 | 06:35 AM
RealStreet's Avatar
PMs replied
Old Jun 1, 2010 | 05:51 AM
RealStreet's Avatar
Monday Bump!
Old Jun 2, 2010 | 12:42 PM
RealStreet's Avatar
bump
Old Jun 3, 2010 | 06:34 PM
vicsrex's Avatar
sent you pm
Old Jun 4, 2010 | 07:52 AM
RealStreet's Avatar
bump!
Old Jun 8, 2010 | 06:03 AM
RealStreet's Avatar
Pms replied
Old Jun 9, 2010 | 01:35 PM
RealStreet's Avatar
Pms replied
Old Jun 11, 2010 | 05:24 AM
RealStreet's Avatar
Friday bump
Old Jun 16, 2010 | 05:59 AM
RealStreet's Avatar
Pms replied thanks for the sales guys.
Old Jun 17, 2010 | 08:29 AM
RealStreet's Avatar
bump
Old Jun 18, 2010 | 08:25 AM
RealStreet's Avatar
Thanks for the orders guys.
Old Jun 22, 2010 | 11:20 AM
RealStreet's Avatar
Old Jun 23, 2010 | 09:32 AM
RealStreet's Avatar
PMs responded
Old Jun 24, 2010 | 09:47 AM
RealStreet's Avatar
Thanks for the sales guys
Old Jul 8, 2010 | 12:21 PM
RealStreet's Avatar
bump
Old Jul 9, 2010 | 12:26 PM
Octanez's Avatar
bump for a very good trustable guy
Old Jul 10, 2010 | 07:27 AM
RealStreet's Avatar
Thank you man enjoy your parts.
Old Jul 12, 2010 | 02:06 PM
RealStreet's Avatar
bump!
