what kinda oil should be used
Old Sep 12, 2002 | 04:42 PM
RacerXintegra2k's Avatar
Default what kinda oil should be used
Changed my oil today .. and i used quaker state advanced performance 10w30... anyone know if this is good or bad ? what kinda oil should i use in the future ? or what do u guys use
Old Sep 12, 2002 | 05:40 PM
SIK IN DA HED's Avatar
New User
Default Re: what kinda oil should be used (RacerXintegra2k)
quaker state is coo... but i recommend gettin valvoline or mobil1
Old Sep 12, 2002 | 07:13 PM
D.Lansing's Avatar
Default Re: what kinda oil should be used (dlplayboy)
I have recently switched to amsoil and I really like it a lot. With mobil 1, I would lose over a quart every 3000miles, with amsoil the oil consumption is less than half a quart.
Old Sep 12, 2002 | 07:14 PM
GSRaCeRbOI's Avatar
your quaker state is fine.... the interval of the oil change is more important than the specific brand per se... even regular non synthetic dino oil will suffice as long as you adhere to frequent/strict oil change/maintenance schedules... I use Mobil 1 and I change my oil every 3K.. some might say its excessive or whatever but since I do the change myself it doesn't cost too much, only takes me about 20 minutes to do an oil and filter change and I don't mind any added cost or anything to treat my motor well...
Old Sep 12, 2002 | 07:30 PM
B2FiNiTY's Avatar
Default Re: what kinda oil should be used (GSRaCeRbOI)
If your going to use normal oil, I suggest Castrol GTX. Works great
Old Sep 12, 2002 | 08:28 PM
accord-euro-r's Avatar
New User
Mobil 1 5W30
But my GSR always burn about 1 QT of oil every 3000 miles...... Maybe i drove too hard....
Old Sep 12, 2002 | 08:37 PM
New User
Default Re: what kinda oil should be used (accord-euro-r)
well.. i think valvoline is the best. i like it. its good for turbo engines and N/A engines.
Old Sep 12, 2002 | 10:52 PM
NickGSR's Avatar
I recently switched to Amsoil also and I am pleased with it. If your engine is newer (or in really good condition) I'd recommend using the 0w30. I've seen older engines burn 0w30 pretty quickly because the viscosity is so low but it will help lubricate all the little **** which is good when you're engine is seeing high rpms. I used to use Valvoline race oil.. its all good. Although the amsoil you don't have to change as often.. i think they rate it at 20k miles. I'll probably change it at 10k just to be safe.
Old Sep 12, 2002 | 11:34 PM
Volcom's Avatar
Default Re: what kinda oil should be used (B2FiNiTY)
That's what I use. I was using Mobil 1 but felt it was unnessary for me.
dylokjai
Nov 16, 2004 09:47 AM
V-Thang
Acura TL, RL & ZDX
Jan 9, 2004 11:04 AM
blkbeast
May 28, 2003 10:48 PM
NewR
Apr 28, 2002 06:25 PM
TypeR01-424
Aug 17, 2001 07:51 AM
