Wire tuck Demo's
Old May 25, 2010 | 08:32 PM
mogley123's Avatar
Default Wire tuck Demo's
So i been searching the forums trying to see if anyone has any detailed pics or instructions for performing a wire tuck on an EF. I been cleaning up my engine bay and realized it would look a lot better with a wire tuck, however i have no idea how to get started. Im a quick learner and im hoping that some good pics, vids or VERY detailed instructions will set me on the right path. So if someone out there has seen anything that can help me out please send some links thank you.
Old May 25, 2010 | 09:59 PM
DCRB's Avatar
Default Re: Wire tuck Demo's
i have a bunch of pix in my build thread, although its pretty easy. pull the harnesses in through the holes in the fire wall, un loom them then lable each wire, then cut off the plugs, run the wires through the holes just in front of the door harness plug. you will have to extend all the wires on the passenger side, but depending on where you put the ground box on the drivers side you should only have to re solder he plugs to the harness
Old May 25, 2010 | 10:30 PM
Jdm=Ep3's Avatar
ill help you if you make the trek to rancho cucamonga
Old May 25, 2010 | 10:53 PM
codybuRr's Avatar
when i get to doing my wire tuck, imma ****ing drive there to you.
my friend lives in rancho cucamunga, shes going to UTI.
(: cuz i have no idea how to do that stuff. i mean i get the basics, but i would lose my place with all the wires.
Ek973
Welding / Fabrication
Jun 15, 2011 10:59 PM
G2_Fella
Oct 11, 2008 08:21 PM
EJ ITO
Nov 19, 2007 05:35 AM
D16Z6racing
Audio / Security / Video
Mar 21, 2007 05:56 AM
garyc17
16
Aug 28, 2006 09:30 PM
