Turn Signal problem... NEED HELP ASAP
Old May 25, 2010 | 07:16 PM
B-Strat CD5's Avatar
Icon3 Turn Signal problem... NEED HELP ASAP
Don't know what happened but we done traced tracked checked everything wires fuses bulbs and all.. weird thing is everything was fine before paint but now not.. but my turn signals in front corner lights will not work every other turn signal works and blinks just fine.. we have searched everything unless we have overlooked something but has this happened to anyone or does anyone have any advice on how to fix bc i need it fixed ASAP.... any help is greatly appreciated thanks
also car is a 1995 honda accord FYI
Old May 25, 2010 | 08:46 PM
Ghett0_ed's Avatar
Default Re: Turn Signal problem... NEED HELP ASAP
well since it didnt start till after paint i would check to make sure all the grounds are getting good connection to the frame...painters often forget about grounds and dont bother to scuff up the paint under the bolts and therefore causing bad grounds
Old May 26, 2010 | 06:50 PM
already checked and had no luck with either.. its got me and everyone lost
JDM3STAGEVTEC
Dec 17, 2008 04:44 PM
Nate047
Nov 21, 2005 10:11 PM
plonger
Sep 8, 2003 07:15 PM
GeeSaRe
Jun 15, 2001 07:46 AM
