Civic runs rough
Old May 25, 2010 | 07:04 PM
hondalord's Avatar
Default Civic runs rough
My 95 1.5l 16 valve runs terrible. Ive replaced the spark plugs, wires, cap, rotor and coil. The car idles ok but misfires when accelerated. If I pull the spark plug wires off the plugs I noticed that cylinder four doesnt spark when held to the valve cover. Cylinder 3 sparks a little. And cylinders 1+2 cant even be removed from the spark plugs with the engine running or the engine stalls. The only thing I can think of would be the igniter in the distributor but wouldnt this just cause a "no-start" condition? Any help appreciated.
Old May 26, 2010 | 03:14 AM
hondalord's Avatar
Default Re: Civic runs rough
Nobody?
Old May 26, 2010 | 04:05 AM
grumblemarc's Avatar
The Grumpiest
Do a compression test.
Old May 26, 2010 | 05:32 AM
hondalord's Avatar
Ill check compression but it still doesnt explain the spark problem.
Old May 26, 2010 | 01:43 PM
hondalord's Avatar
Anybody else before I put a distributor in it???
Old May 26, 2010 | 07:47 PM
JohnnyBoy87's Avatar
yeah, double check your timing first.
also, do you have an ignition coil?
Old May 27, 2010 | 06:28 PM
hondalord's Avatar
Timing checked out and I tried a new coil but there was no change. New distributor this weekend!
Old May 27, 2010 | 06:35 PM
phaphon's Avatar
try cleaning out the fuel injectors did the exact same thing to me i clean it and my car ran good again
Old May 27, 2010 | 08:42 PM
BatuKing's Avatar
If you are not getting cyl #4 spark, check the dist cap and wires. Sounds like you got a carbon track in the cap which is sending the spark somewhere else.
its not the coil, since if it was bad it would give you no spark.
Noo_Ish_mee
Jun 27, 2016 02:44 PM
sawright
Aug 20, 2013 01:46 AM
ex_ricer
Aug 14, 2008 02:14 PM
homer_eps
12
Apr 9, 2008 08:09 PM
ls19integra95
Apr 15, 2007 11:40 AM
