Timing Marks and Misfire
Old May 25, 2010 | 05:33 PM
854x4's Avatar
Default Timing Marks and Misfire
I'm working on a friends 93 honda civic dx D15b7 and it has no power untill high rpms and has a bad misfire. I think the misfire is do to the sparkplug boots coming apart but the timing might be off one tooth also. If the belt was off one tooth would you still be able to time it at the distributor and line up the red 16 degree mark?
Old May 25, 2010 | 07:28 PM
shawn_crx's Avatar
Default Re: Timing Marks and Misfire
If it's off 1 tooth it'll a little be hard to adjust to where u want it.
1 tooth make a lot of difference
Old May 25, 2010 | 08:34 PM
honda_luvr_2000's Avatar
Bad spark plug wires will definitely cause a misfire. If the timing belt is off a tooth it doesn't matter if you can get the ignition timing set right, because the cam/crank timing will still be off one tooth which can/will cause poor performance.
OGCRV2001
Honda CR-V & Element
18
Feb 12, 2015 11:54 AM
dem0nk1d
Jun 27, 2012 12:39 PM
KeithsDAteg
Nov 29, 2009 05:32 PM
jse
Jul 8, 2009 05:03 PM
95greensol
Mar 1, 2005 09:22 AM
