Car shaking update
well i posted a thread a while back that my car shaked while on the freeway at 60+miles well yesterday i changed the Rear trailing arm bushings and it still shakes but not as much what eles can be the problem ?
well it onlt shakes side to side on the freeway and the tires are new and there tighten down good , can it be that it needs alignment??
If you have a steering wheel 'shimmy' at highway speeds, it can be bad driveshafts as well.
If your entire car shakes at highway speeds, it's either a wheel balancing issue or a wheel weight has fallen off, or flat spotted tires (from sitting for 1 year or so)
Do you have wheel locks ? Check to see if you have locking wheel lugs. Some locking lugs are as much as 1.5 ounces heavier than the other lug nuts which translates to about 1/2 ounce at the wheel rim. It can throw balance off.
read this entire page too
http://www.aa1car.com/library/vibrations.htm
and just curious how will alignment fix the shaking ?
