Suspension problem.. help!!
So I took my 99 Integra to Firestone so they could get it alligned, because of the recent drop I made on it. And it turns out I need a camber kit, lowering arms, etc etc etc... which turns out to be over 2000 dollars!!! So now I have to ride with uneven tires. All because I droped it. Does anybody know if I really need all that stuff? If not, then where can I get it alligned.
You don't need a camber kit or lowering arms, all you need to make sure is that your toe is zero'd out, keeping it from pulling. Yes, your tires are going to wear uneven aka inner will wear slightly faster than the outer and its not really a problem. Go take your car anywhere you feel comfortable spending your money, actually just give it to me.
What they told you is completly false.
2k for what!? Camber kits, even with install shouldnt even cost half of that, 2,000 is totaly insane.
Read the thread on top, This should explain it all to you. You dont need a camber kit, and unless your runing a large amount of negative camber the entire tire still touches the ground, opposed to what most people will say. Your tires will eventually wear but not very quickly. I have been lowerd for a year without an alignment, ( i know,stupid) and my tires are hardly wearing.
Tell them to set the toe at OE spec, and dont touch anything else. Negative camber issnt such a bad thing either, It can help with handling.
yeh most shops will try to get you for your money you have to watch that stuff. your tires are going to wear a lil more but thy just wanted you to get the parts so they could charge you to put them on i would just bring it elsewhere
vdawg559
14
Sep 26, 2008 07:33 PM
eclypzex
Oct 6, 2004 01:28 PM
