What sand paper grit should I use to smooth out primer?
Old May 25, 2010 | 01:34 PM
Mad-Mike's Avatar
Default What sand paper grit should I use to smooth out primer?
On some parts of my car I spray too much primer in one area an was wondering what grit sand paper should I use to smooth it out? Also right now I got 1500 and 2000 grit paper on me if that would work.
Old May 25, 2010 | 05:45 PM
00sihok's Avatar
Default Re: What sand paper grit should I use to smooth out primer?
sanding out primer should be done with 400 grit sandpaper
Old May 25, 2010 | 08:35 PM
drift2004's Avatar
400 is good !!!!
Old May 26, 2010 | 06:18 AM
gorillafart's Avatar
it all depends on what you're gonna be doing with it... are you going to be sanding it to primer again?... or sanding it in preparation for sealer? or basecoat?
Old May 26, 2010 | 06:20 AM
kelsodeez's Avatar
derp resistant
truth.
for another coat of high build, you can use as gritty as 180. if you are getting it ready to seal and paint, wet sand with a block and 400 then wetsand again with 600.
Old May 26, 2010 | 10:29 AM
Mad-Mike's Avatar
I am just looking for a grit to sand it down to smooth it out with the body because I spray too much primer making it thicker than the body.
Old May 29, 2010 | 12:42 AM
Civic-Kids's Avatar
400 - up
Old May 29, 2010 | 07:45 AM
candyman206's Avatar
At work we block primer out with 220 for a straighter cut, then 320 to get rid of the scratches, finish it off with 600.....but the final sand all depends on brand of material being sprayed. Standox line doesnt like 600, it'll shrink and show.
Old May 29, 2010 | 11:43 AM
Junk-CRX's Avatar
What brand of primer would you guys suggest?
Old May 29, 2010 | 02:30 PM
Spawne32's Avatar
400, 600 imo is too fine for basecoat
kelviiv
Paint and Body
11
Feb 11, 2011 07:45 PM
00trdtaco
Paint and Body
Dec 15, 2008 01:47 PM
doobiesack23
Jan 16, 2003 11:35 AM
eh-D
Aug 5, 2002 11:30 AM
