For those with JDM Shift Boots...
Old Sep 12, 2002 | 04:04 PM
kkim's Avatar
Default For those with JDM Shift Boots...
Does the stock 97-98 shift **** fit into it like does the USDM one or did you have to modify the **** base to get it to get it to accept it?
Just got a JDM boot off a fellow H-T member and am trying to determine if I got the correct part. # is 83414-ST7-Z10ZA
If this is the correct part #, are they not designed for the **** to "click" onto the shift boot like it does on the USDM version?
I know, no big deal, but I was expecting it to fit like the stock boot.
thanks
Old Sep 12, 2002 | 04:28 PM
hungsteR's Avatar
Default Re: For those with JDM Shift Boots... (kkim)
Is doesn't click like the 97-98 shift **** boots. I have the same setup...JDM shift boot and 98 ITR leather ****. Just screw the shift **** all the way down and it will look fine. I'll try to get some pics later.
Old Sep 12, 2002 | 04:45 PM
kkim's Avatar
Default Re: For those with JDM Shift Boots... (hungsteR)
okay, thanks.
does this mean that the JDM cars have a different shift ****? if so, is it any different from the USDM *****? if so, why?
Old Sep 12, 2002 | 05:16 PM
DaRKniGhT ITR's Avatar
I didnt need to modify anything...i have a 00 ITR...i did have to use the metal part from the bottom of the stock shiftboot...the one they use in the japenese R is bigger...
Old Sep 12, 2002 | 07:27 PM
ITRmike98's Avatar
Default Re: For those with JDM Shift Boots... (DaRKniGhT ITR)
yea, where do you get one like these from?
This looks like a civic....
[Modified by ITRmike98, 11:28 PM 9/12/2002]
Old Sep 12, 2002 | 07:33 PM
B2FiNiTY's Avatar
Default Re: For those with JDM Shift Boots... (ITRmike98)
Wow, goes all the way down.
Old Sep 12, 2002 | 08:11 PM
kkim's Avatar
okay... I took the metal piece from the stock boot and switched it with the plastic piece that comes in the JDM boot. It's held onto the underside of the boot with ties wraps. After the switch, my boot/shiftknob now looks like the one in the picture. I little more hassle than I was expecting, but I like the end result.
Old Sep 12, 2002 | 08:17 PM
B2FiNiTY's Avatar
Very nice, I never knew you could do that.
Old Sep 12, 2002 | 09:26 PM
There ya go.....congrats....the JDM ITR shiftboot is hella kool..
Old Sep 12, 2002 | 09:35 PM
BlazinITR's Avatar
New User
What is everyone talking about?
The JDM shift boot is just like the OEM ITR boot, but with red stiching! It was just like any other bolt on replacement. I'm glad that I had the Helms manual to assist me with taking my console off. Would of never known where all the bolts was located with out breaking the plastic panels. If you want to compare? I'll take pictures for you guys!
Cal
Old Sep 12, 2002 | 09:38 PM
kkim's Avatar
Default Re: For those with JDM Shift Boots... (Blazin ITR)
what year ITR do you have? for 00-01, this is not an issue because of the different shift **** that they have.
Old Sep 12, 2002 | 09:58 PM
BlazinITR's Avatar
New User
I guess, that way I didn't have a problem, because I own a 2K ITR.
Just a n00b
Oct 22, 2018 07:19 PM
passwordjdm
40
Nov 9, 2010 08:18 AM
johnclaunch
May 24, 2006 11:31 AM
JDM yo!
May 22, 2006 11:58 PM
andrewasf77
Nov 10, 2002 11:50 AM
