JDM headlights flasher connector where could I find one?
I bought a JDM front clip, and one turn signal socket is missing
I never seen a socket look like this one, and I want to know where I could find it on another car/year/model
thanks a lot
thanks a lot
you can use the corner one from a 96-00 honda civic... one of the little tabs may have to grinded down.. just a little.
actually if you want the jdm connector, it will only blink not stay on constantly, I believe that socket can be found on a 94-97 accord front lower blinker. honda can get u the socket and pigtail. sheekdude suggested a civic blinker but the stock one from and integra will work the same way (just need to trim it a bit)
civic EK 96-00 turn signal/corner lights are 3 pins
integra JDM is only the turn signal so 2 pins
I will try to find an Accord
