squeeky clutch pedal
Old May 24, 2010 | 11:16 PM
Etorres325's Avatar
Default squeeky clutch pedal
i have asqueeky clutch pedal annoying, could this be a prelude to a problem? how can i correct it/catch the problem before it starts. Or does it just need a little grease?
thanks
Old May 24, 2010 | 11:50 PM
Linked's Avatar
Default Re: squeeky clutch pedal
figure out where the noise is coming from, it could be from the slave cylinder, hitting the shift fork
but if your sure the sound is from the pedal, i'd grease up the bolt that holds the pedal
and check the master cylinder
zach1288
Jan 21, 2010 03:16 PM
Basically
11
Feb 13, 2007 04:33 PM
FuNkDrSpOt
Oct 10, 2006 09:48 PM
puertoroc7976
Sep 7, 2006 03:06 PM
HeelToe
Mar 20, 2002 05:07 PM
