place racing mounts
Old May 24, 2010 | 10:14 PM
jdm206's Avatar
Default place racing mounts
do the place racing mounts set the engine really low? im having a problem with the crank pulley rubbing against my front cross member strut rods. my car is pretty low too.
Old May 24, 2010 | 10:19 PM
StayKrafty's Avatar
Default Re: place racing mounts
I had place racing mounts on my bseries swapped hatch, and I also had this problem.
Old May 25, 2010 | 07:51 AM
Ass$nyper's Avatar
Pirate General...YARRRR
It's rather common on most mounts not just places, notch the member, smash it or get a different x member.
Old May 25, 2010 | 08:45 AM
hatchet_honda's Avatar
im running an innovative mount front x member. i have hydro hasport b series mounts. and by looking at it itd still hit proly even with the hasports if i still had the oem x member on there. notch it x2
Old May 25, 2010 | 01:46 PM
Jaime 91SiB18's Avatar
I used to have them, they suck. Motor placement is too far forward.
You need the CTR N1 single belt crank pully to avoid interference with the radius rod.
Old May 25, 2010 | 10:42 PM
jdm206's Avatar
i might try using my n1 pulley, or i might just pull out my motor and throw my hasport mounts on.
Old May 25, 2010 | 10:52 PM
i have the hasport mounts along with the n1 pulley...made things alot easier and no clearance issues
Old May 26, 2010 | 07:57 AM
.Manny.'s Avatar
Touching My Member
Try the B16 pulley. Been on my B20V and b16 and have never had a problem with rubbing. But I'm using Innovative Steel Mounts
Old May 26, 2010 | 08:10 AM
EL Vap133's Avatar
I did not have that problem with Place Racing mounts but I got them used back in 2001. I switched over to Hasport once they got the hydro tranny conversion though.
SRACHAD
Feb 26, 2006 01:24 PM
WhiteLightening
16
Jan 4, 2004 08:29 AM
Josh717
12
Oct 28, 2003 05:34 AM
crxguy05sir
May 27, 2003 09:53 PM
b19coupe
Mar 24, 2003 09:11 AM
