Radio and headlights cut off..
Old May 24, 2010 | 06:53 PM
omg_miiiike's Avatar
Default Radio and headlights cut off..
00 itr..
It's been hot out lately so I don't know if this can be related to the main relay issues but every so often my radio will cut off and back on and a few times the headlights went with it. The car also randomly shut off once on me but never did it again, any other ideas as to what this may indicate??
Old May 25, 2010 | 06:01 PM
fcm's Avatar
fcm
Old Fart
Default Re: Radio and headlights cut off..
The radio and head lights have absolutely nothing to do with the PGM-FI Main Relay, [main relay],
My guess it is an electrical issue, I would start by checking/redoing the main grounds, remove, clean both contact surfaces, reconnect.
If problem persists, do the same with the main power connections, make sure main fuses a screwed in tight. 94
Old May 25, 2010 | 08:35 PM
honda_1's Avatar
i had the same problem i found out that my battery connections wasn't so good so i cleaned them and it all stopped doing that.
lrice
Jul 22, 2011 07:16 AM
Quad-Damage
Mar 27, 2008 01:21 PM
Hando
Oct 10, 2007 02:27 PM
es_squared
Jan 13, 2006 01:34 PM
turbohatch98
Jul 6, 2003 06:36 PM
